Build Advice Urgent question needs answer ASAP please
Discussion in 'Hardware' started by Teelzebub, 18 Dec 2015.
  1. Teelzebub
    27 Nov 2009
  2. MrGumby
    MrGumby CPC 464 User
    27 Apr 2009
    Ive built one of these for a friend. They aren't bad for web browsing and a bit of word. Gaming wise they are poor. Due to the single channel memory and weak igp. Hope that helps.
  3. Parge
    16 Jul 2010
    The minimum system requirements for the sims 4 show it would run it. But it definitely won't be a good experience.
    • PROCESSOR: 1.8 GHz Intel Core 2 Duo, AMD Athlon 64 Dual-Core 4000+ or equivalent (For computers using built-in graphics chipsets, the game requires 2.0 GHz Intel Core 2 Duo, 2.0 GHz AMD Turion 64 X2 TL-62 or equivalent)
    • MEMORY: At least 2 GB RAM
    • HARD DRIVE: At least 9 GB of free space with at least 1 GB additional space for custom content and saved games
    • VIDEO CARD:
      128 MB of Video RAM and support for Pixel Shader 3.0. Supported Video Cards: NVIDIA GeForce 6600 or better, ATI Radeon X1300 or better, Intel GMA X4500 or better
    Office and youtube would be generally fine, as long as you aren't streaming at 1080p with a load of chrome tabs open or whatever.
  4. Teelzebub
    27 Nov 2009
    Thanks so probably not the best solution, The problem is she's on a low budget of £150 and is running out of time.
  5. Teelzebub
    27 Nov 2009
  6. nimbu
    nimbu Modder
    28 Nov 2002
    Your issue with those will be the poor igp experience and when trying to upgrade then you have to take into account that it has to be a lp card which limits options and adds on cost.
    Other than that they are pretty solid, I have a E8400 based one still going strong.
    They dont appear to have any normal form factor refurbs for me to suggest.
  7. Vault-Tec
    30 Aug 2015
  8. nimbu
    nimbu Modder
    28 Nov 2002
  9. David
    7 Apr 2009
    Tel, is this a Christmas deadline?
  10. Vault-Tec
    30 Aug 2015
    The rig I posted costs £209 after adding the CPUs, GPU, hard drive and ram.
  11. Teelzebub
    27 Nov 2009
    It was but I've given the money back tbh she's left it bit late really .
  12. Teelzebub
    27 Nov 2009
    £150 is all she has
