Windows URGENT - redirected folders backup
Discussion in 'Tech Support' started by adam_bagpuss, 29 Jun 2010.
  1. adam_bagpuss
    24 Apr 2009
    Hi,
    Im not that tuned up when it comes to servers and i shall bore you the story of why i need to do this but its a "worst case scenario".
    i need to copy all the contents of the companies redirected folders (not many around 5 or 6) to an external drive.
    obvisouly the problem i have is permissions. now im not sure how to alter the permissions without altering/overwriting exisiting ones so i can have access to everyones documents and make a copy.
    anyone any ideas ?
  2. saspro
    saspro IT monkey
    23 Apr 2009
    What OS?
    Do you have admin rights?
  3. adam_bagpuss
    24 Apr 2009
    lol oops
    its server 2008 and i have network administor role
  4. saspro
    saspro IT monkey
    23 Apr 2009
    Either.
    1) Manually change permissions on each folder by taking control of it then adding yourself to the ACL.
    or
    2) Use shadow copies to copy the files to the external drive (use it as the target)
    or
    3) Use your backup software to make a copy to that drive.
  5. adam_bagpuss
    24 Apr 2009
    tried to copy a shadoe copy to a new location and it was denied, seems i require permissions still
    know any that are free that will copy even if i dont have permissions ?
    if i take ownership of each of the folders wont this effect redirected folders and then they wont be accessible by the user ?
  6. saspro
    saspro IT monkey
    23 Apr 2009
    If you're running full server 2008 then you can use the built in backup software to do it (you may need to install the feature)
    If you take ownership of a folder it shouldn't affect the current permissions unless you change them. I usually take control, give myself full control then change the owner back.
  7. adam_bagpuss
    24 Apr 2009
    hmmm the backup software only allows me to make a backup of the whole C: drive but im guessing its a compressed image file (or something similar) so i wont be able to access files individually
  8. adam_bagpuss
    24 Apr 2009
    when i try to change permissions of the my doc folder or desktop folder and add the admin user i get an acess denied message !
  9. saspro
    saspro IT monkey
    23 Apr 2009
    Have you tried logging in as Administrator, browsing to the folders & looking at previous versions then drag & dropping them to a drive.
    If it's just for backup then it doesn't matter if you can see/open the files.
    If you're trying to steal the data or snoop on people then it's another matter (not for a public forum)
  10. saspro
    saspro IT monkey
    23 Apr 2009
    Have you taken control first?
    adam_bagpuss likes this.
  11. adam_bagpuss
    24 Apr 2009
    basically my boss has asked me to do it and hes the director of the company so no stealing or whatever.
    hmm i probly didnt take control first but im gunna use a work around to make things easier and so i dont break the server.
    since we have very few users im just gunna log in to each PC (3 or 4) and make a backup of of docs and desktop. shouldnt take long and im scared about breaking the server.
    thanks for super fast responses though sapro +rep
  12. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    Take ownership. It won't break the permissions. If you're really worried, simply check the security permissions and make sure the relevant user already has permissions setup (which they should do). If they're listed, go ahead and take ownership.
  13. saspro
    saspro IT monkey
    23 Apr 2009
    If you want me to remote in to the server let me know.
  14. adam_bagpuss
    24 Apr 2009
    lol thanks for the offer but im sure my boss would kill me. ive sorted it now and backed up all the PCs i need to.
  15. saspro
    saspro IT monkey
    23 Apr 2009
    I could charge him if he want.
    That way it's like getting a consultant in.
    A bargain at £750 a day.
    :D
