US Air Force secretary says directed energy weapons should be used on US citizens
Discussion in 'Serious' started by Cthippo, 22 Sep 2006.
  1. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    OMFG!!! What else can you say about somthing like this? :sigh:
  2. yodasarmpit
    yodasarmpit Modder
    27 May 2002
    Better to be hit with one of these than a bullet tbh.
    Great idea.
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    doesnt microwaves make you sterile? and cause cancer and other mutations?
  4. Nexxo
    23 Oct 2001
    That's particle radiation much further up the spectrum. The exact effects of microwaves on people are unknown, however. Needless to say, if it is powerful enough to hurt, it is powerful enough to do damage.
  5. specofdust
    specofdust Banned
    26 Feb 2005
    At least they're not testing the stuff on Iraqi's.
  6. Nexxo
    23 Oct 2001
    How do you know they're not? :D
  7. Will
    Will Beware the judderman...
    16 Jun 2001
    Actually, I'm sure I read something that they were deploying a vehicle mounted system which sounds very much like this to Iraq quite some time ago, on a small scale for 'developmental' purposes :worried: I'll try and find it again.
  8. specofdust
    specofdust Banned
    26 Feb 2005
    One must try be optimistic in these matters :sigh: :D
  9. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    In extreme cases, it might be prefered to other measures such as gas or rubber bullets. A Boston college student was killed by police a while back when they fired rubber bullets into the crowd. It hit her in the eye or something.
    It'll probably give people intense pain such as bad sunburn sensations.
  10. Cthippo
    7 Aug 2005
    Ever put tinfoil in the microwave? How about a CD? Got coins in your pocket? Rivets holding your Jeans together? How about a zipper (OUCH!). THink about it, they may be using this on you some day. They certainly sound like they enjoy the idea :(
  11. Stuey
    20 Jan 2005
    The metallic objects one has on them won't be an issue. The basic principle of microwave ovens is that they vibrate the water molecules in the food. Hence, increased vibrations is translated to thermal energy.
    They don't want to zap your rivets and zippers - they want to virtually cook you for a split second, hence the intense pain I mentioned.
  12. hujambo_Bwana
    hujambo_Bwana What's a Dremel?
    2 Aug 2006
    If you want to know what it feels like to be zapped with microwaves goe to a dockyard and stand infront of a Navy Radar. Apparently you feel slighty warm, then you feel dizzy and sick, then you die as all your internel organs have been cooked.
    NOT very nice.
  13. Cthippo
    7 Aug 2005
    Unless the metal acts as an antenna and arcs to your skin, which could easily cause localized burns of a pretty serious nature. I think the article mentioned that this was enough of a concern that they had volunteers involved in the testing of this remove all metal objects from their bodies and also remove contact lenses.
    I agree that this is a better alternative to existing means of riot control, but what scares the hell out of me is that the government sees it's use not as a last resort, but as a desireable example to the rest of the world that we used it to inflict pain on our own citizens before we used it to inflict pain on people overseas. Call me naieve, but in't the government supposed to protect the citizenry from such threats?
  14. Stuey
    20 Jan 2005
    I think we're all taking it a little out of perspective. I see it more as "if we're willing to use it on our own people as a safer and more efficient non-lethal riot control technique, then there should be no outcry if we choose to use this oversees on a non-American populace".
    They've been working on other similar stuff for a while now. Out of sonic and visual, and directed energy harassment, the focused energy seems to have won out.
  15. DXR_13KE
    14 Sep 2005
    ok, it heats up liquids, most of your body is liquid, but as i see it, people would go blind and infertile with this, right? if it heats up liquids it will heat up your eyes making them dry, and heat your testicles. for Cthippo this would not be a great deal since he does not want to breed, but i want kids!!!
    no ofence there Cthippo ;)
  16. DaSuperFly
    DaSuperFly What's a Dremel?
    19 Apr 2002
    Er microwave in your kitchen is tuned to make water molecules vibrate. The military version doesn't necessarily do the same thing.
  17. cderalow
    cderalow bondage master!
    23 Jan 2002
    i've heard of using low level sound waves to make people extremely uncomfortable before... but microwave?
  18. Cthippo
    7 Aug 2005
    No problem, DXR :D
    Actually, I think the danger of sterility is overstated. I did some research on this a few years back for a friend and basically found that the danger from microwave radiation is pretty much systemic. Either it cooks you whole, orit doesn't do any permanent damage. As I've said before, my concern is for localized burns and possible electrocution form different electrical potentials on different parts of the body and to ground.
    If someone wants to prove me wrong, go right ahead.
  19. DXR_13KE
    14 Sep 2005
    another thing springs to mind...... "torture device".
  20. _DTM2000_
    _DTM2000_ Minimodder
    9 Feb 2005
    I read recently that during the testing of this device, no test subjects were allowed to wear glasses due to them magnifying the beam and causing eye damage. They also found that any solid objects like buildings or the ground could reflect the beam and cause hot spots with sometimes double the original power. I think this was in New Scientist.
    Of all the nonlethal things they could have used, I can't understand why they chose microwaves. I just don't see how they're ever going to stop hot spots, as once the beam has left the "gun" it's unpredictable and uncontrollable.
    EDIT: Here are the articles I read:
    Microwave weapon 'less lethal', but still not safe
    Microwave weapon intensified by sweaty skin
