Other usb 3.0 front bracket
Discussion in 'Hardware' started by stormbringer500, 13 Mar 2013.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
    Hi I got a usb 3.0 to go into the back of the case with my motherboard, is there a cheap way of switching the brackets over I cannot seem to find one.
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Wouldn't be too hard to modify a blanking plate to fit them?
  3. Parge
    16 Jul 2010
    Or you can buy them at almost any computer store/ebay.
  4. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    You mean the case front panel has pass through cables meant to plug into the ports on the back? Mine also had this, I took a somewhat ghetto approach...
    as I got one of these with my motherboard, I removed the pci bracket and have it inside with this and the passthrough plugged into it and bunched the cables up between the motherboard tray and the 5.25 bay. It gets the job done and I didn't have to buy anything else.
  5. stormbringer500
    6 Jan 2010
    I don't now what I would have to buy if took the pci bracket off for it to go in a bay on front of case.
  6. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Is this what your after stormbringer?
  7. IvanIvanovich
    31 Aug 2008
    Maybe one that is made for the HAF is your ticket? Assuming you are asking about the case from your sig.
  8. lancer778544
    5 Jan 2011
    Even better.
  9. stormbringer500
    6 Jan 2010
  10. lancer778544
    5 Jan 2011
    Go for the bracket that IvanIvanovich linked to, its designed for your HAF 932.
  11. stormbringer500
    6 Jan 2010
    Yeah probably will go for that just one problem the spacing between the usb 3.0 ports are they all standard cause some brackets look close together don't now if that one would line up with my usb 3.0 ports.
  12. IvanIvanovich
    31 Aug 2008
    Huh? The usb3 ports/cable come with it all as one assembly. You get exactly what is shown, all you have to do replace drve bay blank with this usb3 version and plug the cable to the usb3 header.
  13. stormbringer500
    6 Jan 2010
    I meant when remove the pci bracket would it line up with the new bracket becuase doesnt look like it in pictures
  14. IvanIvanovich
    31 Aug 2008
    You don't need to do that. The first of my post I was talking about making it yourself, but you sounded like you were more intrested in a drop in solution maybe, so there you are, no modding required it already have the usb ports installed in a HAF style bay blank.
  15. stormbringer500
    6 Jan 2010
    Ok thanks for the advice, I will be buying this one http://www.cmstore.eu/cases/haf/haf-932/haf-932-5-25-usb-3-0-bracket/
