Storage USB 3.0 speed
Discussion in 'Hardware' started by academica, 5 Jun 2012.
  1. academica
    academica What's a Dremel?
    15 Oct 2010
    I bought a notebook Pavilion dv6-7025tx with Intel i7-3610QM processor, which has native USB 3.0 support. I attached an external disk Seagate FreeAgent GoFlex with USB 3.0, which has Maximum External Data Transfer Rate of 640 MBps (5 Gbps) according to http://www.provantage.com/seagate-staa1000101~7SEGS252.htm. However Windows 7 Home Premium x64 says the transfer speed (when copying) is 99 MBps.
    Would anyone kindly explain the 6 times slower transfer rate of USB 3.0
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Hard drive limitation. Mechanical hard drives can only go so fast and that's generally around 100MBps for most drives. You've fallen prey to a bit or marketing, that's the theoretical maximum for the USB 3.0 connection. You're very unlikely to ever see that sort of speed even if you got an external SSD.
    PocketDemon likes this.
  3. academica
    15 Oct 2010
    Thank you, noizdaemon666 for your time to answer my question. Obviously the trades people advertise the theoretical values and it's the user's responsibility to find out the real values of things we buy.
  4. teppic
    teppic What's a Dremel?
    18 Jul 2011
    You are still getting significantly more speed than you would with a USB 2 drive, if that's any consolation.
