News USB 3.0 to get 10Gb/s transfer rate
Discussion in 'Article Discussion' started by Gareth Halfacree, 7 Jan 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. mi1ez
    mi1ez Minimodder
    11 Jun 2009
    I hope they call it 3.1 rather than sticking with 3.0 and making us read the small print constantly and explain to friends and relatives why their new drive/PC isn't as quick as they were expecting...
    l3v1ck likes this.
  3. Blackshark
    Blackshark What's a Dremel?
    13 Apr 2004
    Erm..... well given the time it will take 3.1 to actually appear on host devices (MBs) and consumer devices, I think its a mute point.
  4. Tangster
    23 May 2009
    Take that stupid proprietary standards.
  5. MjFrosty
    MjFrosty Minimodder
    3 Aug 2011
    Worst. Industry. Ever.
  6. Guest-23315
    Guest-23315 Guest
    Isn't 5Gbps fast enough?
    I mean.. that theoretically an entire 1Tb disk in under three and a half minutes...
  7. yuusou
    yuusou Multimodder
    5 Nov 2006
    Gigabits != GigaBytes.
    1 Gigabit = 128 MegaBytes.
    Meaning 10 Gb/s = 1.280 MB/s
    Assuming you meant a 1TByte disk, that means copying everything over, theoretically, if you're always at peak speed, will take 13 minutes 40 seconds. Also assuming the data actually occupies 1TB.
  8. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Maybe Apple have learnt from there mistakes with Firewire and Thunderbolt will be a success, But personally i will be steering clear of TB due to its association with Apple and there past history with propriety hardware.
    So its good to hear of a faster USB even though i only use it for simple things like keyboard/mouse
  9. [-Stash-]
    [-Stash-] What's a Dremel?
    23 Nov 2005
    Should be called USB4, just keep things simple.
    Other than that, good news!
  10. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Technically thunderbolt isn't apple, intel were the inventors or whatever you want to call it, apple just heavily invested in its development. It has appeared on some motherboards recently.
    People don't use thunderbolt because it far too expensive, and standard hdds cant reach the speeds anyway.
  11. Corky42
    30 Oct 2012
    @fdbh96, yes but Intel signed a exclusive deal with Apple for one year (coming to a close soon)
    Apple has always tried to get as much mark up as possible from hardware, a 2M TB cable costing £30, a 2TB HDD costing £290 and the equivalent USB 2TB £90.
    By closing TB off for a year (maybe more) it enabled USB3 to get a foot hold in the market and in the end its about what connection your device comes with and whats cheapest.
  12. Gareth Halfacree
    4 Dec 2007
    The exclusivity deal is already over: you can pick up Thunderbolt-equipped motherboards right now, if you're willing to part with the cash.
  13. ArthurB
    ArthurB What's a Dremel?
    17 Jul 2011
    What's the new 100w USB 3.0 standard going to be called? Are we going to have two different USB 3.0 standards: 100w 5Gb/s USB 3.0 and 900mA 10Gb/s USB 3.0?
    I wish they would get their act together!
  14. atomo
    atomo What's a Dremel?
    28 Dec 2005
    Good for USB, but Thunderbolt is still faster. Not only is Thunderbolt 10Gb/s but it's also bi-directional, which means 10Gb/s in BOTH directions.
  15. ch424
    ch424 Design Warrior
    26 May 2004
    This is a bit strange. Surely Intel has a massive investment in USB3 too? I wonder if this is anything to do with simplifying everything. Intel published an idea for a common PHY (PDF warning) which means that you might as well have all the interfaces running at the same signalling rate.
    I wish USB would disappear though; it's such a hassle to develop for compared to Firewire and Thunderbolt/PCIe.
  16. law99
    law99 Custom User Title
    24 Sep 2009
    Isn't USB 3 full duplex now?
  17. Gradius
    Gradius IT Consultant
    3 Feb 2009
    Keep in mind it NEVER NEVER NEVER will reach true 10Gb/s, is always less, probably around 7Gb/s. It should be called USB 4.0. Or go directly to true USB 4.0 instead. Thunderbolt will be expensive until 2015~2016, plus we don't ever see much devices using that any time soon.
  18. play_boy_2000
    play_boy_2000 ^It was funny when I was 12
    25 Mar 2004
    I'll take the power consumtion improvments, but for a port that I'm just as likely to plug a keyboard into.... who cares?
  19. PCBuilderSven
    PCBuilderSven What's a Dremel?
    3 Oct 2010
    I assume you meant 10Gb/s = 1.280 GB/s
  20. alialias
    alialias What's a Dremel?
    1 Dec 2010
