Peripherals USB expansion card
Discussion in 'Hardware' started by Kronos, 3 Jul 2017.
  1. jaribecker123
    jaribecker123 What's a Dremel?
    1 Jul 2017
    thanks it works for me
  2. spolsh
    spolsh Multimodder
    4 Feb 2012
    The only thing with monitor USB hubs is, at least on my Dell, if the monitor went to sleep the USB would disconnect.
    jaribecker123 likes this.
  3. Kronos
    Kronos Multimodder
    6 Nov 2009
    I will only be using the extra USB's to connect cameras when I need to download images so not likely to be an issue.
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Is that such a bad thing? Only my keyboard & mouse are plugged into the monitor. If the monitor's asleep, I'm unlikely to need those.
  5. spolsh
    spolsh Multimodder
    4 Feb 2012
    Does your PC wake from the monitor when plugged in there ? Mine never did. It's worse if you decide to read from USB disk over a network and it disappears ... just realised, a wake on LAN alert would probably have solved that.
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Is this question aimed at me? If so I am not sure what you mean.
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    Responding to IanW's comment Kronos, and no, it's not going to be a problem for the cameras you wish to connect.
  8. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    TBH I don't let my monitor sleep. That's what the power button is for.
