Windows USB flash memory key driver
Discussion in 'Software' started by BjD, 15 Jun 2004.
  1. BjD
    BjD What's a Dremel?
    10 Apr 2003
    I got a cheap USB flash memory key from eBuyer (64mb), which works fine so far on Win2000 computers. However I come to try it on my mum's Win98 machine and it cant find a driver :( Ive tried the 98 CDROM and windows update but it cant find the right one. eBuyer says it supports 98 with the supplied software, but I dont think I got a CD or floppy with it :S. I have :search: and tried driverguide but can only find drivers for specific manufacturers, and I dont know who made this one. any help please?
  2. lessthanjake
    lessthanjake What's a Dremel?
    24 Jan 2004
    hi i think the website you are after is www.supertalentflash.com if that doesn't work reply here or PM me and i will see what i can do
  3. BjD
    10 Apr 2003
    Thanks mate, that is the right manufacturer but neither the USB1 or 2 drivers work. No great problem as i think ive talked mum into upgrading this computer anyway so should hopefully have XP on it soon :thumb:
