Hey guys, Ive been looking evrywhere for ages but I can't find the type of crimp terminals used in firewire/usb/audio headers. I have managed to get a picture of the spec but I just can't find it in the huge lists of catalogues Please help! Pic of spec
Thnakyou SO MUCH Did you already know it or did you find it? Because these things take me aaaages to find :S
I've bought them before. I assume you've found the housings, if needed, but if not then they're from the Harwin M20-106 series e.g. single pin is 1060100, 2 pin is 1060200 etc. 20 pin housing for USB 3.0 motherboard connection is M20-1071000
How do you remove the pins from the housings? I have tried to use a 0.5mm jewellers screwdriver but that is still too thick. Can you use a needle to push up the plastic tab, or are they too fragile? PS. Thanks for the housings as well
