Portable USB help
Discussion in 'Hardware' started by Mechh69, 8 Oct 2012.
  1. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    How many devices can a usb port recognize at one time? Here is what I am looking to do, I have a laptop it only has 3 USB ports. At the moment I am out of laptop hard drives so I want to mod one usb port and make it 2 USB ports so that I can use a mouse and a memory card for the OS. If i solder from the back of the port on the lap top and add another port in with the computer recognize this as 2 separate devices if I have 2 things plugged in? A picture for reference.
    Below I want to solder these 2 ports together, will the computer recognize these as 1 or 2 ports if I have 2 devices plugged in?
  2. Lorquis
    Lorquis lorquisSpamCount++;
    8 Sep 2002
    NO. This will not work. What you need to do is pull the lines from the original port into a small USB hub, then have the 'original' port and the new port come off that..
    Look at old EEEPC 701 hacks for inspiration..
    Mechh69 likes this.
  3. Mechh69
    16 Sep 2009
    Thank you Looking there now
