USB Hub help
Discussion in 'Tech Support' started by AJB2K3, 8 May 2008.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Ok I'm having this issue with usb hubs in that I can only use a keyboard/mouse will only work on them.
    I need to run
    MX232 LCD,
    Bearpaw/PB 1200+ scanner
    DVD Duel Layer W/RW,
    120GB HD,
    ipod dock,
    SE w810i dock
    USB Air rifle
    PSP,
    2 X thumb drives.
    All from only 2 USB PC ports.
    Can someone recomend a powered hub(s) that will do the job?
  2. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    any USB hub by a decent brand with an external power plug should do the job just fine.
  3. AJB2K3
    12 Dec 2005
    Well having a chat today and it seams there is a problem with PB/bearpaw usb scanners running through the hubs.
    Would a patch lead with a dedicated 5v across the power line work?
  4. mansueto
    31 Aug 2007
    again, get a hub that has an external power source (plugs into a wall outlet) that way it doesn't draw power from the pc, and you still get a fully functional usb hub.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Can you add a plug-in (PCI) USB card to your mobo with a few more ports? One problem could be that a hub is sharing the bandwidth to everything plugged in, and some of your stuff needs a lot of bandwidth. Mice and keyboards don't need much.
  6. mctigger
    mctigger What's a Dremel?
    11 Feb 2007
    bandwidth will definitely be an issue with a Hub. Recently used a hub with two web cams, it was externally powered, and it couldn't sustain a decent data through put. have a look into the pci usb expansion card, for the equipment that will need more bandwidth. then use a hub for the less bandwidth hungry things!!
