Electronics USB Keyboard
Discussion in 'Modding' started by Lamer than Lame, 24 Feb 2002.
  1. Lamer than Lame
    Lamer than Lame What's a Dremel?
    11 Feb 2002
    Is it possiple to make an old PS/2 keyboard work on a USB connection???
  2. eaterofpies
    eaterofpies What's a Dremel?
    12 Feb 2002
    i think u can get convertors ps2>usb and usb>ps2
  3. Lamer than Lame
    11 Feb 2002
    I know about the usb to Ps/2. But i tried to find any Ps/2 to USB and they don't exist!! :mad: so what do I do???
  4. Sgt. Gimp
    Sgt. Gimp What's a Dremel?
    11 Nov 2001
    I don't know where you live, but in the UK, Maplins have a USB device (part number TJ62S) that has two ps/s ports, one each for your K/B and mouse. It is priced at £24.99.
  5. Lamer than Lame
    11 Feb 2002
    Yeah I know about those, but the price on those things is two high. For the price of one of these I could buy 3 USB standard Keyboards. I live in denmark by the way...
  6. macroman
    macroman The One
    3 Sep 2001
    I think you will find that unless the keyboard is designed to work with USB just using a converter won't work :(
  7. KevinOwns
    KevinOwns What's a Dremel?
    13 Jan 2002
    What is wrong with using your PS/2 port? I could see if it was broken or something, but it works just fine otherwise.
  8. Lamer than Lame
    11 Feb 2002
    Hmm. Okey. no solutions... :(
    Regarding the Ps/2 port: I don't have one...
    And you might ask. who would sell/buy a comp without a PS/2???
    well that would be me... And my adwise: DON'T DO IT!!!
    stay away from fujitsu/siemens: Celvin. I bought it from a friend to use as a server, very cheap. But thats the worst thing I have ever bought.
  9. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    I would just go with a usb keyboard... now adays their so cheap. I agree with Macro, even if you found a converter, I don't think you would be happy anyway
