USB KVM
Discussion in 'Hardware' started by sk8ter646, 22 Feb 2007.
  1. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    hi there i already have a Belkin usb kvm i bought for £25 however it doesnt do 1440 * 900 so i have to turn one pc off at the wall to get the proper resolution
    it will do no widscreen but i need widescreen so can anyone point me to one that will work for me
  2. Hiren
    Hiren mind control Moderator
    15 May 2002
    I recently picked one up from mappers that claims 1920x1080 support, will find out make / model for you tomorrow.
  3. sk8ter646
    4 Oct 2005
    cool that would be great
  4. Hiren
    15 May 2002
    Maplin Code A26GH - Petite USB KVM - CS-62U
    I've had no problems with mine so far supports multi button mice as well.
  5. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    The resolution that one supports isn't mentioned - whereas this (admittedly more expensive) Sitecom one definitely supports up to 1920 x 1440 :thumb:
  6. Hiren
    15 May 2002
    The Aten Petite one I mentioned definitely supports up to 2048x1536 I know this because I'm looking at the manual right now.
  7. Hazardous
    21 Jan 2004
    Fair enough :cooldude:
    But I didn't know that until now, and I don't have the benefit of the manual :D
  8. sk8ter646
    4 Oct 2005
    will they run in widescreen though mine is ment to support up 2500*1500
  9. Jipa
    5 Feb 2004
    I never even thought there's such resolution limitations on KVMs! Good point, I've been using my D-link DKVM-2KU at 1680x1050 resolution when it's specified at 1600x1200. That's not a major difference in 1600 and 1680 though so I'm not surprised it works fine.
    (BTW I'm using my monitor through analog input)
  10. kurabii
    kurabii What's a Dremel?
    10 Jul 2006
    try finding DVI-monitor USB KVM for a decent price... its a kick in the shins hahaha
    ESA
  11. Jay Shiyani
    Jay Shiyani What's a Dremel?
    6 Aug 2007
    DKVM-2KU
    hi can some help me please! i just got DKVM-2KU, the problem is i have a dell computer which keyboard and mouse connection is usb, the other computer keyboard and mosue connection is ps/2. How can i solve this? i tried to connect everything up and connected my mouse (usb) to the device to see whether this will work (if it did i would have purchased a usb hub and have my keyboard and mouse connected to that) however the DKVM-2KU only boots if the ps/2 connectors are connected.
    so now im thinking the keyboard and mouse are ubs so is there a adoptor which i can connect the device to and change it to ps/2 connection? or do i need to get a ps/2 connection mouse and keyboard? if so how does this connect to my dell pc because that is usb only no ps/2 ports!!! someone please help!!!:duh:
  12. b0ned0me
    b0ned0me I won't upgrade anything this month
    7 Aug 2007
    Avocent Switchview is what you need...
    I had a four-port VGA KVM from them that ran up to 1920*1200 with not a peep of complaint. It also had a USB hub and audio switching, which was nice. It also supported USB keyboard & mouse but with limited support for 'extra' buttons, so I used the USB hub ports instead. Rock solid bit of kit, but hard to find due to limited distribution.
    I recently switched to a Switchview DVI, which is equally awesome apart from being a bit finicky about the way it's initially powered up - I end up leaving it powered on all the time.
    The only good bit of Belkin kit I've ever encountered are their network cables, which are nicely made but very expensive. Anything with actual chips or moving parts - forget it.
    Jay - sounds like you need some of the little green / purple USB->PS2 adaptors like these? Back in the day you used to get them with every decent USB keyboard or mouse to prevent exactly the problem you're having. If you have a mate with a big box of old PC clag he'll probably have some, if not they're a quid or two off ebay. Just search for usb ps2 adaptor.
