Hi Guys This has popped up on my grandsons pc and I need you help in understanding what the screenshot below means. Any help will be much appreciated.
One of the usb connected devices is overloading I think. You can try booting up with one in at a time. Disconnecting the case front usb may be worth checking too. Edit: or a bios issue although I can't see it all of a sudden it being that unless something new was added.
Do you have any USB hubs (splitters) plugged in? Very likely to be too many high power USB devices plugged into a single USB port on the tower. As above, try only basic USB devices first (keyboard and mouse) and then plug the rest in to see whats what. Could also be a fault on the mobo and/or USB port being reported back through bios.
It's a spare 3.5mm lead, probably audio from somewhere. Sorry, I had to - it's one of those mornings...
Thanks for the replies adidas & spraduke , I’ll need to speak to my grandson and check how many usb devices he is trying to connect. Appreciate the humor ModSquid
