Networks Usb over network
Discussion in 'Hardware' started by AJB2K3, 2 Apr 2011.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I intend to buy my house and have usb network adapters in each room.
    Apart from
    So far all I kind find is Lantronix UBox 2100
    Is there anything cheeper i.e single usb port?
  2. Deders
    Deders Modder
    14 Nov 2010
    How come you want USB adapters in every room?
  3. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    Same as deders, why?
  4. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    Agreed, I can see little point in this.
  5. AJB2K3
    12 Dec 2005
    Because I have devices in each room ! that can't be put in the same place.
  6. tehBoris
    30 Jan 2011
    Can't you locate the devices in one room then access them via the network?
  7. AJB2K3
    12 Dec 2005
    there isn't the space. The pcs are laptops, the modem is in a different room, the printer in another, Camera and Kindle in yet another, and storage in hidden in another.
    as there no desk/office its easer to use network nodes spread around the house.
  8. tehBoris
    30 Jan 2011
    For storage you would be better off getting a device that is specifically intended for it, same with the printer (would be surprised if you couldn't get a box that would do both). Though you will need to check compatibility with the printer.
    Plug the kindle in to the laptop, same for the camera if it's a digital still camera.
  9. adam_bagpuss
    24 Apr 2009
    USB over network is quite expensive
    your looking £200-300 for hubs
    USB1.1 is very cheap though can get adapters for £15
