Motherboards USB pin confusion
Discussion in 'Hardware' started by HandMadeAndroid, 9 Mar 2010.
  1. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    :wallbash:
    I got a new small case for some old parts I have knocking about. Unfortunately due the the exhaust fans location, I'm unable to connect the front USB headers. I didn't think this to be an issue as I have a spare PCI slot and managed to purchase one of these cards:
    http://www.sunix.com.tw/it/en/Product_Detail.php?cate=2&class_a_id=34&sid=335#
    However the connection block for the front headers has one hole blocked, this would match perfectly with the headers on the Asus board which has a key way with one pin missing (5pin). The internal card I received through the post has 6 pins! Firstly is this normal; should I cut one pin off lol?
    Thanks :thumb:
  2. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    looks like it has normal 5 pins each.. make sure pin 4 is ground and cut off the right pin- those last 2 aren't even connected to anything.. you can probably look at the board and see
    if you cut off the wrong end you won't get any power
  3. HandMadeAndroid
    18 Feb 2005
    Thanks for that, I think I can see where two pins, if you follow the green tracks, they lead nowhere. I'm going to get a second opinion before the pliers come out...thanks again!
    :thumb::D
