Modding USB socket replacement
Discussion in 'Modding' started by akanekal, 19 Jun 2005.
  1. akanekal
    akanekal What's a Dremel?
    4 May 2005
  2. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    It doesn't really take a genious to figure it out, you just have to get the pinout for the mini-USB jack and match it to the plug.
    You will probably have to file the hole up, glue the jack in place and connect it with wires to the circuit board since i am pretty sure the footprints don't match.
