Modding Useful Links (Materials)
Discussion in 'Modding' started by modgodtanvir, 22 Apr 2008.
  1. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    I thought it might be a good idea to start a quick list of all our favourite sites for building materials around the world. No components or tools, I'm talking sheets of this and rods of that. Good things to put here would be:
    Metals
    Sheets of aluminium, steel, whatever else...
    Rods of aluminium, steel etc.
    Those aluminium bars with plastic connectors
    Anything else
    Plastics
    Plastic sheet
    Acrylics
    Foams
    Plexi
    Perspex
    Polycarbonate
    Resins and Fibreglass
    Epoxy resin
    Fibreglass
    Other
    (maybe safety equipment as well actually)
    Anything Else
    Things like mesh, tubing etc.
    I think such a post would be of great benefit, and if we get some good links, maybe sticky it in the future. To get the ball rolling:
    UK
    Plastics:
    The Plastic Shop: http://www.theplasticshop.co.uk/
    Brilliant source for reasonable priced plastics of all types.
    (Sorry if such a thread already exists. I couldn't find one, even when I used the search.)
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    www.hindleys.co.uk great shop for tools and materials especially aluminium and acrylic.
    josh
  3. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    I'd really appreciate it if there's any place in the US to get (relatively) inexpensive carbon fiber. Just the fiber, I believe you can use regular 2-part model airplane epoxy?
  4. marcus000
    marcus000 Watercooling Mad
    7 Aug 2007
  5. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    bringing this back from the dead a bit.
    Where do people get their spray paint etc. from. I had a look on a few vendors websites but asking people in the know is usually the best bet.
    Also bondo!?
    I could contribute a place to get Mesh. WCUK sell it in 500x500 mm squares
  6. modgodtanvir
    28 May 2007
    Wahey
    Cool.
    Spray paints can be found on a number of websites, including art and craft sites and car parts stores. My favorites however are found on eBay. Shops such as: http://stores.ebay.co.uk/CAR-ACCESSORIES-R-US_Spray-Paints_W0QQcolZ4QQdirZ1QQfsubZ15QQftidZ2QQtZkm
    sell a selection of paints and primers. The search also brings up results for Candy paint and pearlescent paints which can also be found here (for all our airbrush enthusiasts):
    http://www.thecustompaintshop.com/Shop Areas/cat/Paint+-+Auto+Air+Colors
    When I can't be doing with the wait for delivery however, I pop down to the Motosave down the road (or Halfords) and pick up a few cans of whatever.
    Things like Krylon can also be found on eBay.
    I went out on a search for bondo once but apparently its not sold in the UK. However, in Halfords, I came across something called Isopon P38, which is an easy-to-sand filler, much like bondo, and does the same job perfectly.
  7. DaveVader
    10 Aug 2007
    Halfords is the shop I was desperately trying to remember the name of! I knew they sold this kind of stuff.
    I will look for "bondo like stuff" when Im out an about. Im thinking of doing a project on a CM690 (after practicing on some older cases of course)
  8. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    screwfix is cheaper for body filler £8 for a big tub
  9. DaveVader
    10 Aug 2007
    ah I forgot about ScrewFix! My dad is an electrician so uses them a lot. Will take a peek in the catalogue :thumb:
  10. bentleya
    2 Feb 2008
    in the automotive section for the body filler, bolts are cheap on there too
  11. Cheapskate
    13 May 2007
    I only know of Tap Plastics. I've never shopped for CF, so I don't know if their prices are good.
  12. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    McMaster Carr is excellent for US modders. They have mesh, alum, steel, and various shades of cast acrylic.
    Performance-pcs.com is a good source of AC Ryan supplies, including nice 3mm UV acrylics.
    For extruded alum channels and the such, the easiest place to purchase is from the local hardware store. It's not exactly easy or cheap to order 6-8ft lengths to be shipped, and smaller length are typically costlier.
    In addition to Tap plastics, I keep hearing good things about Delvies.
  13. jhanlon303
    7 Sep 2006
    check out www.fiberglast.com I have used them in the past.
    John
  14. tuaamin13
    tuaamin13 What's a Dremel?
    27 Apr 2008
    What about custom acrylic etching in the States? I'm not planning to use etched acrylic any time soon, but it's one of those things that can be filed under "good to know."
  15. DaveVader
    10 Aug 2007
    this is going to sound a bit stupid but ... Sandpaper in packs of different levels of coarsness (right wording?)
    but anyway, I've looked a few places and none of them seem to do "variety packs"
    Edit: or at least not in the variety I want. I think I need to pop down to my local DIY store sometime soon.
    Edit 2: uneeded now, I realised I should stop being so lazy, it's not all about internet shopping!
  16. karolis
    karolis Code Monkey
    10 Mar 2008
    Anyone know any quality powdercoating and anodizing service providers in UK? And what prices roughly should i expect?
    Also, does anyone happen to know how military firearms are treated to achieve that nice black look? What metals can it be applied to?
  17. swift_wraith
    swift_wraith I love you Pig.
    3 Mar 2008
  18. modgodtanvir
    28 May 2007
    The OCZW boys do a powdercoating service for a fairly good price. They anodize as well.
    http://www.overclockerzwatercooling.com/index.php?act=viewCat&catId=6
    You could also try:
    http://www.watercoolinguk.co.uk/catalog/index.php?cPath=86&osCsid=a5uq0bocu0riuivlba9pa9h297
    They do custom etching as well.
    Prices for powder coating a whole case start at £85.00
    The black gun colour is quite cool, quite matte, not glossy. In a sense it appears to be the colour of the metal itself rather than painted, so maybe anodising might work? M-16s are made of aluminium... Custom cars also do it:
    So airbrush paints might be available...
    EDIT: might it have something to do with metal flakes?
  19. karolis
    karolis Code Monkey
    10 Mar 2008
    Now that's a beautiful car. :jawdrop: and the color is exactly you described. i looked at gunmetal color paint, but it just doesn't have that smooth finish
