Education Useful Phrases/Words/Idioms
Discussion in 'General' started by Guest-23315, 16 Jan 2013.
  1. Guest-23315
    Guest-23315 Guest
    Going from KRONOS's thread here: http://forums.bit-tech.net/showthread.php?t=255420
    An interesting concept, so, turning it on its head, what are the Words/Phrases/Idioms that you actually find helpful and good advice?
    If it doesn't work there is something wrong
    Pretty simple, and applicable to almost everything in everyday life.
    Rather obvious, but also easy to forget in the heat of the moment.
    Needs must when the devil drives (needs must)
    (Blackaddedr: Needs must when the devil pisses in my kettle)
    I take this as its always better to get stuff over and done with as quickly as possible, rather than waiting and worrying. It might suck in the short term, but it makes everything better in the end.
  2. steveo_mcg
    steveo_mcg What's a Dremel?
    26 May 2005
    Free advice is seldom cheap
    59th rule of Acquisition...
    Worth remembering if a shop offers you a free test, or Kwik-fit invite you in for a free MOT or battery test.
  3. GeorgeK
    18 Sep 2010
    Lol - I love the Rules of Acquisition
    A particular favourite is #112
    "Never have sex with the boss' sister"
  4. Tangster
    23 May 2009
    Measure twice, cut once
    Essential if you're doing any DIY.
  5. Cookie Monster
    Cookie Monster Multimodder
    27 Aug 2003
    One I've used them at work when someone says a shop round the corner has the same item cheaper but they don't have them in stock.
    "I give them away when I don't have them"
  6. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    One for work especially when apprentices are here.
    If it ain't broke, don't fix it
  7. badders
    badders Neuken in de Keuken
    4 Dec 2007
    Buy Cheap, buy twice
    Though most of the time I've found that the alternate also holds true: Buy expensive, still buy twice
    So have combined these into:
    Buy cheap, buy twice, but buy expensive, buy twice, so you may as well just buy twice cheap to start with, and get it all out in the open.
  8. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    If you don't ask, you'll never get. - The amount of people who 'wait' for things to happen for them or expect people to do x, y & z for them.
    No harm in asking the majority of the time.
  9. Krikkit
    21 Jan 2003
    Too often the case, although the original adage holds true on cars. :p
