Windows User Permissions
Discussion in 'Tech Support' started by VipersGratitude, 16 Sep 2017.
  1. VipersGratitude
    VipersGratitude Well-Known Member
    4 Mar 2008
    Recently my Windows installation has become a little confused...It won't let me save files to the desktop, instead throwing up a dialog box that says:
    ...and if I click yes to save to the Pictures folder the same dialog box appears. The problem is the user account I'm using is an admin account - Anyone have any ideas as to what the problem might be?
  2. Kernel
    Kernel Likes cheese
    29 Sep 2003
  3. adidan
    adidan Avatar is back out of season.
    25 Mar 2009
    That was the first thing i came across googling it... o_O
  4. VipersGratitude
    4 Mar 2008
    Me too, but honestly, I didn't bother to read the whole thread....Just the do-the-same-crap-you've-already-tried part, and discounted it.
  5. CodyWA
    CodyWA New Member
    20 Nov 2017
    Try to reset the admin account into your own account? Here is how change it: https://kb.iu.edu/d/arni
    Not sure if this is what you asked for....
  6. Corky42
    Corky42 What did walle eat for breakfast?
    30 Oct 2012
    Is it safe to say that didn't work then or that it's still causing a problem, if so you could try using tweaking.com's Windows repair tool, most of what it does can be done manually and you probably won't want to run all the things in the repair section but it's sorted some stuff for me in the past.
