[User Review] GTX480 Waterblocks Roundup !
Discussion in 'Watercooling' started by bundymania, 22 Jun 2011.
  1. bundymania
    bundymania Bastelorakel Industries Worldwide
    4 Jun 2009
    Hey guys,
    today, I want to give you an overview of the currently available waterblocks for the NVidia GTX 480. I had nine different blocks around for testing. While high performance CPUs are using less and less power, this is a trend that can't be seen when looking at high end VGA-cards and so fullcover blocks are getting more and more interesting for users of NVidia's and AMD's flagships. In this roundup I want to compare temperatures and flow rates of the blocks. As the NVidia GTX480 does already come with high heat build-up as standard and is able to use radiators to full capacity, I disclaimed overclocking in this review.
    Firs t of all I want to say that every block was able to cool the card appropriately and quietly. When choosing the block that's good for you, you shouldn't only look at the top ranks in this roundup, but take a look at the complete package: looks, build quality, price, temperatures, mounting and flow rates. As it turns out, blocks with microfin-structure were able to perform best once again and so it comes as no surprise that the blocks, that are pretty much the same inside are very close together at the top.
    The included backplate with some of the models proved useful, as it's mounted on the back of the card for more contact pressure, especially in the area of the mosfets. Also, this plate can help to prevent damage to the card.
    So let's get to the way I tested:
    The test system:
    Banchetto 101 Bench Station
    Gigabyte GA EX58 Extreme (Biosversion: F7)
    Mips Fusionblock Nickel
    i7 920 @4Ghz @1.40V (BIOS Setting)
    Cougar GX 1050 PSU
    Corsair XMS3 Dominator DIMM Kit 6GB PC3-12800U CL7-7-7-20 (DDR3-1600)
    EVGA GTX480 VGA-Card
    Mora 2 Pro / 9x Noiseblocker PL2 (600 RPM)
    Aquaero VFD
    Laing Ultra with Koolance Top
    EK Waterblocks EK Multioption Reservoir 250mm Advanced
    Aquacomputer flowmeter
    Koolance VL3N & CPC Metall quick release couplings
    Masterkleer & Primochill 16/10 tubing + Perfect Seal and Bitspower fittings
    3x Watertemp sensors (2x T-Line, 1x in reservoir)
    1x dig. sensor in the reservoir for calibration
    Thermal paste: Gelid Extreme
    Innovatek Protect
    ArctiClean for cleaning the card and the blocks.
    [​IMG] [​IMG]
    My special thanks go out to the company EVGA for offering me the required GTX480 VGA-card!
    [​IMG] [​IMG]
    Testmethod:
    To fully load the card, I used Furmark v.1.8.2 (settings: 1280*1024, 8x MSAA). As mentioned before, the card ran at stock speeds.
    I used Gelid Xtreme for this test. Every block was mounted three times with new thermal paste and the best run of all three was used for the end results.
    As the Geforce GTX480 doesn't come with sensors to monitor the temperatures of the mosfets, I used the relevant temperature of the GPU, that I monitored using GPU-Z. The water temperaute was monitored using an Aquaero and several calibrated (inline) sensors. The reading was taken when no change in temperature was visible and the maximum value was reached, but not before one hour has passed.
    The waterblocks in detail:
    Watercool HEATKILLER® GPU-X³ GTX480
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    For years, the waterblocks by Watercool.de were able to score big in a lot of reviews worldwide. The block for the GTX480 was also able to do the same.
    Outstanding build quality, delicate looks and of course the impressive temperatures, reached by the means of good design and so-called microfins directly above the GPU.
    Watercool made a block that's very thin, taking a step away from the modular style of older blocks, which were very popular because of their upgradeability.
    The waterblock looks a lot more like the products of another German manufacturer, a very basic design and a thin corpus made out of copper, paired with a stainless steel plate carrying the name of the new cooler series. Mounting this block was easy and quickly done.
    This block also convinced me when it came to performance. With an adaptor which is sold separately, you can also use up to four waterblocks of this kind in SLI. The scope of delivery can also be called good: the box contained the required mounting material and an easy to understand manual, thermal paste is not included. Paste is used on the GPU only, the other cooled parts are connected via thermal pads, which come pre-cut, which is time-saving. The block fits the card very well, for good contact pressure in the area of the mosfets there's a mini-backplate, used on the back of the card.
    Technical data:
    Material: Copper, stainless steel, POM
    Size: 172.0 x 117.0 x 11.5mm
    Weight: 850g
    Threads: 4x G ¼" (DIN ISO 228-1)
    pressure tested: 5 bar
    Scope of delivery:
    1x HEATKILLER® GPU-X³ GTX480
    1x Backplate GTX480
    1x mounting material/manual
    Price: ca. 87 Euro
    Aquacomputer aquagraFX for GTX 480 (GF100) nickel plated
    The second block out of Germany is this product by Aquacomputer.de. I received the nickel plated version for this review, only differing from the standard version in its surface and its price, as it's a little more expensive. This block makes a very solid impression and looks pretty good. It's milled out of one copper block and topped by stainless steel carrying the manufacturer's emblem. The inner design is similar to the one seen on the block by Watercool, so it's not surprising that this block performs just as well. The scope of delivery includes a manual and the required mounting material, but once again, thermal paste isn't included.
    As a little bonus, a backplate out of stainless steel for creating better contact pressure and avoiding bending the card is also included. This works well, so well, that you don't have any doubts when using thermal paste instead of pads on the memory. There's also an adapter available for using up to seven cards in SLI with this block.
    The mounting is simple, only when putting the backplate in place you have to be patient. You have to be extra careful not the move the backplate when putting the spacers in place.
    Overall, this block by Aquacomputer knows how to impress, especially in this nickel plated version!
    Here's a little video about the manufacturing process of this block:
    YouTube - Making of aquagrafx GTX 480
    and a mounting video:
    YouTube - aquagrafx GTX 480 Installation
    Scope of delivery:
    Block without fittings (threads: G1/4")
    Backplate out of stainless steel
    Mounting material incl. pads
    two sealing caps
    Price: ca. 89€ for the normal version and ca. 99€ for the nickel plated version
    EK Water Blocks EK-FC480 GTX - Nickel
    Let's get to the block of the Slovenian manufacturer EK-Waterblocks. This block is, as usual for EK-WB, available in several versions: There are variants with tops in black POM and acrylic glass and the cooling surface itself is available in copper or nickel. A backplate isn't included and is available for around 20€ in two different versions. Adapters for using several cards in SLI are also available.
    Let's get back to the block itself. It comes in a nice orange/black retail box with a manual. This box also includes the required mounting material; thermal paste is only used on the GPU itself, thermal pads for the other components are also included, which have to be cut.
    The EK-FC480 GTX in this nickel plated version impresses in performance and build quality, but it's not easy to install it on the card. The spacers have to be glued to the block using thermal paste - this could be done another way, just like other manufacturers do it.
    Mounting the card in the area of the mosfets didn't work that well without the backplate which is sold separately, you really have to check the pressure.
    Overall, the EK block is a good product that scores a lot because of the high amount of variants.
    Here's a little video, where you can have a look at the block:
    YouTube - EK Water Blocks EK-FC480 GTX - Nickel
    Scope of delivery:
    block without fittings (threads: G1/4")
    mounting material
    thermal pads
    2x sealing caps
    illustrated manual
    Price for the nickel plated version: ca. 82 EUR
    Backplate sold separately.
    XSPC Razor GTX480
    The English company XSPC produces this block. The very slim block is called XSPC Razor GTX480 and is the cheapest block in this review. The performance is good, though not as good as some other blocks. Mounting was easy and the scope of delivery can be called "complete". The required thermal paste was also included, unlike with most of the other blocks.
    This block uses thermal paste on the GPU and pads, which come already pre-cut, on the memory, too.
    Conveniently, the spacers are part of the block and so no complicated mounting is required. Sadly, a backplate doesn't come with the block, but even without one, the block was mounted quite easily with the correct contact pressure.
    This XSPC block is well made out of copper with a top out of stainless steel and is also compatible with SLI-systems.
    Because this block is very thin (only 9mm!), the threads are screwed on and not part of the block itself. Spacers might be required, but are included.
    On one side, there's a sticker for the warranty, slightly disturbing the look.
    Technical data:
    Material: copper plate, nickel plated top
    Threads: 4 G1/4"
    Size: 170 x 124 x 9mm
    Scope of delivery:
    1x XSPC Razor GTX480
    1x Thermal paste
    2x sealing caps
    2x spacers
    thermal pads
    mounting material
    Price: ca. 75 EUR.
    Koolance VID-NX480 (GTX 480)
    Koolance have been around for more than ten years in the watercooling scene and have produces quite a lot of successful products.
    That's why they also came up with a block for the GTX480, called the VID-NX480. Robust, massive, impressive - these words came into my mind when unpacking. The block is shipped in a black retail box with a rich scope of delivery. The bottom plate is made out of black nickel plated copper and in the middle, there's acrylic glass, that's lit by two 3mm blue LEDs. Useful: These LEDs get their power via the 4-pin fan-power on the VGA card. There are also other colors available at the Koolance store at an additional charge. The top is made out of stainless steel, carrying the company emblem which offers some insight in the inside of the block.
    Because the fittings are very far apart, you can easily use every sort of fitting on this block, even though some fittings might require spacers. Of course this block is also SLI-compatible, adapters are sold by Koolance or 3rd-party-companies. This block also comes with two large thermal pads that the users has to cut to use them, giving more than enough material for another installation. Just like every block, I also disassembled this Koolance block after testing and fount out, that the Koolance-guys more than the required amount of grease in this block, leaving easily visible traces of it in the block and the system. I spoke to Koolance about this issue and they stated that the newer blocks made since the end of July 2010 contained less grease, so that this problem shouldn't exist anymore.
    Overall, this still is a great block, offering very good performance and great build quality. Only the rather expensive price in Europe and the grease weren't that great.
    Video of installation:
    YouTube - Koolance Nvidia GTX480 Waterblock: Part 5, ... & Finish
    Technical data:
    Material: nickel plated copper, acrylic glass
    thread size: G1/4"
    Size: 15.9 x 14.6 x 1.6 cm
    Weight: 680g
    Scope of delivery:
    Koolance VID-NX480 (GTX 480) Full Cover block
    Thermal pads
    Thermal paste
    mounting material
    Price: ca. 120 EUR
  2. bundymania
    4 Jun 2009
    Bitspower VG-NGTX480
    Now, I'd like to present the block by Bitspower, carrying the Name VG-NGTX480 and it's available in six versions.
    The amount of variants is nice, but they only differ in the colors of the top and the LEDs. The middle is made out of acrylic glass, while the bottom is black nickel plated copper.
    The block is very massive and makes a good impression. The scope of delivery is complete: Everything needed for mounting and usage is included in the black retail box, even high quality thermal paste, a replacement o-ring and two twistable adapters for the two G1/4"-fittings. In contrast to all the other blocks in this review, the threads are on the front of the block, making these adapters especially useful in small cases to avoid crashing into the side. The installation itself is pretty easy because of long spacers screwed into the block and small screws on the back of the card.
    The mentioned middle part can be lit and the top can be removed for other looks. For this review, I received the block with a black top, visible in the large picture.
    This block fits my card very well and the contact pressure is good, but the high price of almost 150 EUR and the achieved performance couldn't convince me. Of course the GPU temperature of the GTX480 was 30° less than with the stock cooling, but still this block couldn't score well. The block's design is missing the microfins and a backplate, also extra screws in the area of the mosfets.
    Technical data:
    Size: 180 x 108 x 20 mm
    Threads: 2x G1/4"
    Scope of delivery:
    Arctic Silver Matrix 2.5G thermal paste
    replacement o-ring
    2x BP-BS90R Black Sparkle Adapter
    Price: ca. 150
    Danger Den DD-GTX480 Black Chrome Top and Nickel Base
    The American company Danger Den is one of the established manufacturers in the watercooling business and shiny acrylic cases. They also offer a fitting block for the GTX480, that I've got here for testing.
    This block is also sold in different versions with different surfaces and therefore also prices. There's for example a copper version and another one with a nickel plated top.
    For this review, I used the block that's completely nickel plated, but I also ordered a black top for better looks. This block is very heavy with more than 1100g and makes a very solid impression. It fits well and mounting is done very easily using the included manual. In case of problems, you can also have a look at Danger Den's video on YouTube.
    This block also uses thermal pads for all the components instead of the GPU, for which some thermal paste is included in the white box. Two barbed fittings are also included and can be chosen via the online shop.
    The block's bottom is made out of copper with channels for cooling as seen in the picture above. The area around the GPU is very wide, explaining the low resistance to water. A microfin structure would have improved the performance, though.
    A backplate for this block isn't available.
    There's a video available about this block's installation:
    GTX480 Videos | Videos
    Innovatek Cool-Matic GTX 480
    [​IMG] [​IMG]
    When having a look at other manufacturers, it took a rather long while for the Bavarian company Innovatek to come up with their block for the GTX480.
    Of course, I want to show you how this 200€ - expensive block performs.
    The build quality is, as known from Innovatek, flawless and comes with a very complicated cooling structure. In the GPU-area, they chose a nickel plated copper bottom plate with a fitting microstructure jet element, which is screwed onto the bottom plate and is supposed to offer good performance. Because of this structure, you have to be careful not to mix up the in- and the outlet - the manual in three languages helps not to.
    The block itself comes in a white retail box containing the block, the required mounting material and a rather short, but illustrated manual. It also contains some thermal paste, which is probably supposed to go on all the cooled parts - the manual doesn't cover this at all.
    Because of its length, this block is very heavy, but still sits well on the card without bending it; even without a backplate it comes with the required contact pressure.
    The scope of delivery also includes two screw-on-fittings for 10/8-tubing.
    The Cool-Matic GTX 480 is SLI-compatible with its four threads for fittings, but not all fittings will fit here because they're very close together.
    Scope of delivery:
    Cool-Matic GTX 480
    Required mounting material
    Thermal paste
    DUAL SLI fitting terminal
    Screw-on-fittings for 10/8mm
    retail box
    manual
    Swiftech MCW80 GTX480
    This review's odd man out is this block made by the American company Swiftech. They use passive cooling for most of the parts, while only the GPU itself is cooled by the water, which is also available standalone to use with other components on other VGA cards.
    This block costs around 100 US$ and comes in a white retail box with all that's required for the installation, also including thermal paste. The thermal pads are already cut and stuck to the passive cooling element, so that you only have to remove the protective foil. The manual comes in English, French and Spanish. Two barbed fittings are also included.
    Optionally, you can also mount a 80mm-fan on the passive element, making the mosfets cool down even more. This is recommended when overclocking, as these parts can only cope with temperatures up to 100°C and already get pretty warm when not overclocking. The block's bottom plate is based on the successful Apogee XT CPU-block, so it's not surprising, that the achievement temperature is the best I've seen yet. Still, because of the very delicate structure, the flow rate does suffer quite a lot. Overall, the build quality is good, even larger screw-on-fittings for 16/10 (5/8") tubing can be used.
    Test results:
    GPU to water temperature, less is better
    Durchfluss = Flowrate
    Durchfluss = Flowrate in Liter
    Montagematerial = Mounting Material (easy, eh ? ;) )
    Anleitung = Documentation
    Wärmeleitpaste = Thermal Grease
    Wärmeleitpads = Thermal Pads
    Anschlüsse = Fittings
    Conclusion:
    There's a block for every taste and wallet size in this roundup. As expected, there aren't big differences in the top ranks when it comes to temperatures. Every block in this test is able to cool down the GTX480 a lot better than the stock cooling. You should always look at the whole bundle when buying a block and not only look at these charts.
    I especially thought the Swiftech block was interesting, even though it probably doesn't appeal to all, just as all of these blocks, especially when looking at the price, the chosen materials or the design.
    Luckily, the user can choose between several manufacturers and isn't limited to two or three models, like it was a few years ago.
    Personally, I'd like the companies to make the block easily mountable, the instructions understandable and the scope of delivery complete, for all the users out there. Thermal paste and enough thermal pads are also important for this.
    Thanks for giving me these samples and other parts go out to: Aquatuning USA & Canada , Aqua Computer , EVGA , www.Watercool.de , www.mips-computer.de , www.xspc.biz , www.ekwaterblocks.com , www.laing.de , Bitspower , Koolance, Danger Den , HighFlow NL , Swiftech
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    Awesome work - Thank you very much for your helpful reviews, and espcially the videos.
    I only wish i had found this thread a day earlier :(
    I have an issue with my Koolance waterblock. When installing i noticed that there was a LOT of transparant grease inside the block, and opened it up to investigate.
    Unfortunatley, i cannot get the rubber seal back in place, because it appears to be too long?!! Its easy to work into the channels, but there is too much of it?
    I would really really appreciate some help from someone on this
    thank you
  4. bundymania
    4 Jun 2009
    I have a tip to install the o-ring: hold the ring in position with small stripes of tesa film at the corners and tighten the top only a bit. after that, remove the tesa stripes gently and tighten the screws completly.
  5. Teknokid
    Teknokid Minimodder
    6 Dec 2007
    Very nice review- I had no idea there was that many blocks available for the 480!
    Nice tests as well, although it would be nice to see how restrictive each block is, simple flow results would do - just something to gauge it by.
  6. bundymania
    4 Jun 2009
    The second chart is for for flow results. Durchfluss = Flowrate. Sry for not translating the word directly under the chart :)
