Electronics Using a motion sensor as a on/off button?
Discussion in 'Modding' started by EvilNeverDies, 3 Feb 2009.
  1. EvilNeverDies
    EvilNeverDies What's a Dremel?
    29 Oct 2008
    here's the scenario
    I want to be able to turn my pc on and off by waving my hand above the front of it
    reading into it I need a PIR sensor
    what do you guys think?
    am I on the right lines?
  2. MarkW7
    MarkW7 Total Noob
    30 Nov 2008
    Not sure about the technical things, sounds good but you'd have to think were you put your pc other wise you may move your leg or somethin and it'll turn off.
  3. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    Maybe think about an LDR, and invert the signal?
    I was thinking about the same thing recently, and that was the best I could come up with... You would need to set limits though... you don't want your PC turning on if you turn off the lights... (running an LED off +5vSB to keep the LDR high?)
    Just a few thought's I had until I decided on something different...
    Hope it helps...
  4. devenfore
    devenfore LANCandy
    8 Jul 2003
    Possibly some sort of a laser / sensor setup?
    Maybe put the sensor at the end of a thin matte black tube so that ambient light wont trip it. And then just wave your hand to break the beam...
  5. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    How about an ir setup where you have to break the beam? Like what you see at the entrance of some stores. You can have the ir led & ir sensor on the pc, and the reflector can be wherever, just as long as all three are in alignment.
    eninja: This is just like devenfore's suggestion actually :D but IR
  6. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
  7. mvagusta
    24 Dec 2006
    I couldn't get a touch switch to work without actually touching it, but the biggest piece of metal i used as a trigger was about 10 x 4 cm and ~1mm thick.
    IIRC, the datasheet states that going much bigger than this means the touch switches apparently become overly sensitive and can be falsley triggered.
  8. Cheapskate
    13 May 2007
    Someone in the project logs did something similar with the cd tray button. I don't remember who it was though.:(
  9. EvilNeverDies
    29 Oct 2008
    The problem with an IR LED and detector is that I wont have anywhere to put the IR led, as I want to wave my hand over the top of the pc to turn it on and I can't install an IR led in my uni ceiling :p
    and I don't want my pc to turn on when I turn out the lights to go to bed/light gets turned on in the morning
    I've been reading about PIR sensors however I'll need somehelp coding and building it (only got a B at systems in my GCSE's and that was 2 years ago)
  10. mvagusta
    24 Dec 2006
    Oh yeah :duh: like you said in the op! A PIR would be perfect :D
    I somehow drifted off into beams and forgot about the whole proximity thing :D
    This might work well:
    http://www.electronic-circuits-diagrams.com/alarmsimages/alarmsckt19.shtml
    The green link has a circuit diagram - no need for the relay and the attached vertical 9v supply line, just hook the mobo trigger to the collector of the BC107
  11. EvilNeverDies
    29 Oct 2008
    hehe I'm not as n00b as I sound ;)
    I've found another little circuit with some help from another forum that should work and it runs on 5v so should be ok
    but thanks for the suggestion, that circuit works in roughly the same way as the one I'm planning to use so
  12. d33pblue
    d33pblue What's a Dremel?
    8 Feb 2009
  13. d33pblue
    8 Feb 2009
    anybody can help please?:confused:
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Until a cat or something knocked it off, I had a pot frog on the pond wall, a slightly upmarket version of this. Looks a damn cheap way of getting all the parts. :lol:
  15. jhanlon303
    7 Sep 2006
    I have a "Head on a Plate" that has a sensor to make him start talking. Animatronic eyes and mouth.Uses a couple AA batteries. Wave your hand or walk by the head and a tiny pin hole in his forehead senses it and turns on. The head is like this:
    If you look close you can see the tiny hole . The electronics can't be too expensive as the whole head cost $10.
    john
  16. d33pblue
    8 Feb 2009
    lol WTF? **** frogs and heads.:geek:
    i want some electronic schematic sensor to open dvd tray thats all.:worried:
