Modding Using a router to cut a blowhole?
Discussion in 'Modding' started by Steel_Penguin, 30 Apr 2005.
  1. Steel_Penguin
    Steel_Penguin What's a Dremel?
    30 Apr 2005
    Do you think it would work? This is my first mod and I'm Using a Skyhawk MSR4610. My dad seems to think the router will work (he works on boats so he can just borrow one from work) but i'm not so shure. Please help.
  2. Mattt
    Mattt Minimodder
    12 Nov 2001
    as long as your using the right cutting tool, it most definatly will.
    however i doubt you will get as good results as with using a hole saw.
  3. Steel_Penguin
    30 Apr 2005
    The router had a carbide bit so I don't think it'll butcher the aluminum and my dad borrowed a couple of hole saws from his job to make templates (can't use then for the window cuz they're too old and dull to make it through aluminum) so I think it might be okay.
  4. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    As long as you have a good template and a sharp carbide bit you should be ok. I'd recommend using some kind of lube as well, cause aluminum gets 'gummy' when you machine it. If you're planning on making quite a few holes, the template and router combo is king! Are you going to use a plunge-base router, or just cut a starter hole near the edge?
    Drop us a few progress pics and let us know how it turns out!
