Using all 4.7GB of a DVD
Discussion in 'Tech Support' started by nry, 23 Mar 2007.
  1. nry
    nry Minimodder
    1 Nov 2006
    Most likely that there is a simple answer to this.
    I have a bunch of files which total 4.44gb (4,773,531,648 bytes)
    If using nero (only software I have)
    Says there is only 4500mb free on the disk.
    Am i missing something here?
    Dont want to use another dvd just for a few files!
  2. Krikkit
    21 Jan 2003
    4.45GB = 4552.39MB = 4661652KB
    If you have 4500MB free, then there's not enough room for 'em all.
  3. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    basically it's the same reason hard drives report as smaller than the packaging says.
    manufacturer says one kilo = 1000, one mega = 1,000,000, etc. so to them 4.7gb = 4,700,000,000 bytes.
    but in compuspeak it's all powers of two, so divide that by 1024 = 4589843.75 kB. div that through by 1024 again, and you have 4482.269287109375 actual megabytes.
  4. DougEdey
    5 Jul 2005
    That's because a computer normally reads in GibiBytes, MibiBytes, KibiBytes and so on.
    GiB, MiB, KiB
  5. nry
    nry Minimodder
    1 Nov 2006
    And I have a A level in computing, forgot about that
    Thanks lol
  6. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Pretty much as above, storage is measured in powers to the ten (10n) while things like memory (RAM) and OSs measure in powers to the two (2n).
