using an ide hard disk in an ipod
Discussion in 'Tech Support' started by harvy, 4 Feb 2007.
  1. harvy
    harvy Minimodder
    12 Apr 2006
    Prob been asked to death but i :search: and came up with only one forum which is similar but not relevent!
    Google came back with not a lot either.
    Basicly i have a dud 4g 40gig ipod with a dud drive and a broken screen ( not much use most people will say). When i bought it i also bought an ALPINE kit to allow my cars head unit to fully control the ipod (without the need to see on screen) which is where i want to mount the ipod semi-perminantly now.
    The screen is therefore not an issue, the hard disk is however. I dont want to replace it with a 1.8" drive as it will most likely die in a car anyway, i want to connect a cheepo 40gig standard 3.5" ide drive, and ideally run fully off the ipod (ie powered).
    Can someone point me in the right direction to get a board for this or even a pinout where i can create a connector from the ipods 50pin to the ide?
  2. DreamTheEndless
    DreamTheEndless Gravity hates Bacon
    27 Jan 2004
    1. fantastic idea
    2. it has been done before, but I don't have any links for you.
    3. in regards to hard drive selection - the smaller a hard drive, the less it is likely to be damaged by bumps. I realize that it may be more expensive, but you may want to consider a laptop drive instead.
  3. Krikkit
    21 Jan 2003
    You could reverse-engineer one of these. :) Could be tricky though - the connector for the 1.8" drive is a bit specific.
    [edit]On another note, you can get hardened laptop drives for not a massive premium over a standard one.
  4. harvy
    harvy Minimodder
    12 Apr 2006
    Hopefully im gonna utilise an old 40gig i got sitting around (budgets a bit tight!) when that dies then ill prob look towards a lapy drive but at the mo gotta use what i got!
  5. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    cant you just get a small usb caddy, place disk in that, and then plug it into your USB port on the alpine head unit? (that is of course, if it has one)?
  6. airchie
    airchie What's a Dremel?
    22 Mar 2005
    I'm just thinking, the ipod itself won't be able to provide enough power to a standard 3.5" HDD.
    Also, I'm just wondering how you plan to update the songs on it?
    Might prove to be a real PITA.
  7. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    http://www.command-tab.com/2005/03/13/ipod-super/
    but you'll probably have to use a DC-DC adaptor from you car to power the hard drive
    edit: strangely enough that was the second result on google for "ipod ide". people should really learn to search better
  8. harvy
    harvy Minimodder
    12 Apr 2006
    Hi, yea i did find that, but unless ive missed it, theres no info on the acutal pin-outs so cant really use it!
  9. harvy
    harvy Minimodder
    12 Apr 2006
    Nope- the headunit was the pre usb version, it is a special unit to connect only to Ipods.
  10. harvy
    harvy Minimodder
    12 Apr 2006
    anyone know what the connector type/name is on the ipdo hard disks? its alot narrower then the standard IDE... looking for the female if anyones got a direct link!
  11. Lian Li Lover
    Lian Li Lover What's a Dremel?
    17 Nov 2006
    I've seen this on uncyclopedia.org (the only serious article I've ever seen on it) but unfdortunately uncyclopedia won't load for some reason so I can't find you a link
