Modding Using car audio dampening on PC case... your experiences?
Discussion in 'Modding' started by dynamis_dk, 25 Feb 2011.
  1. Guest-23315
    Guest-23315 Guest
    The Intel stock cooler isn't that loud, its normally your GPU heatsink fan which is a whiney little PITA.
  2. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I've found a way around the gfx fan issue - haven't got a gfx card :p
    Onboard Cheesecake
    Its a file server running a commandline linux type setup so no need for fancy gfx here
  3. legoman
    legoman breaker of things
    28 Feb 2010
    From doing various installations in cars etc id recommend a multi layered setup using multi layer matting as in a bitumen mastic layered job which will reduce the resonance of the panels.
    Over the top of that go with a noise barrier foam ideally egg crate style to maximise surface area and the potential to catch the most sound. This will also solve the issue of anything grounding out on the foil backed material.
    Hope it helps
  4. FDAD
    FDAD What's a Dremel?
    7 Mar 2011
    That's fairly nice, a space saver in fact..:thumb:
  5. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Running a unRAID server myself, good software :thumb:
    Like everyone else has pretty much said, rubber mounts for HDD's and low power fans are the go.
    Or just put the box somewhere where you can't hear it :D
    Running headless means you can put it just about anywhere long as you can get a network cable there.
  6. dynamis_dk
    23 Nov 2005
    Well all in all I'm very happy with the results.
    Moved all my gear from a fractal designs R2 into this YY Cube and there a notable difference. Much less hdd noise and that's without the suspension mounting I'm going to use in the end and with a no brand basic hdd cooling fan.
