PSU Using copper rod for 24 pin ATX power
Discussion in 'Hardware' started by Goatee, 14 Aug 2018.
  1. Goatee
    Goatee Well-Known Member
    19 Apr 2015
    I remember seeing a mod a while ago where copper rod (2mm diameter?) was used in place of 18AWG wiring, allowing precise bends to get a set of perfectly symmetrical cables for a 24 pin cable run.
    Despite a bit of searching I cant find it anywhere. Would anyone be able to point me in the right direction or at least tell me I dreamt it and it wont work for x or y reason.
  2. TheMadDutchDude
    23 Aug 2013
    I remember this as well. It looked so good! :D
  3. Big Elf
    23 Apr 2009
    I remember that although I think it was brass rods rather than copper. I seem to recall it was someone who posted it on the overclock.net forum
  4. Dr. Coin
    Dr. Coin Well-Known Member
    13 Sep 2013
    I don't recall it being done for 24 pin atx but for a 6 or 8 pin atx as it allowed the 12 V and return pins to be a bused, thus only two rods per connector.
    If you want to make your own cable that is straight and has sharp bends, replace the #18 AWG stranded copper wire with #18 solid core, or if you want really stiff #16 AWG. Plus it will be insulated so no accidental shorts. If you want a bare look consider enameled coated wire.
    Goatee and TheMadDutchDude like this.
  5. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
    I remember this too. It was done for the gpu pci power cables and for the 8pin Mobo power connection, possibly on separate mods. They did then insulate the rod too. Possibley Melobee?
  6. Goatee
    19 Apr 2015
    Excellent feedback. Pointed me in the right direction. Thanks
  7. The_Crapman
    5 Dec 2011
    Got links?
  8. Goatee
    19 Apr 2015
    Sorry, I’m going with some enamaled single core 18awg. I didn’t find the build. @Dr. Coin ’s description was exactly what I was after and RS can deliver tomorrow.
  9. cobalt6700
    cobalt6700 Active Member
    17 Oct 2005
    Interested to see what you do with this Goatee :thumb:
  10. The_Crapman
    5 Dec 2011
    Found it! Pics are broken though :sigh:
    Can see a few pics in the MOTM article though
  11. Goatee
    19 Apr 2015
    Rubbish on the broken pics. That wasn’t the one I was thinking of.
    Here is where the cable needs to go. A full 70mm run.
  12. faugusztin
    11 Aug 2008
    Goatee likes this.
  13. The_Crapman
    5 Dec 2011
    It's not the one I originally thought of either, but it was the first one I came to trawling through all the morm articles. Haha
  14. cobalt6700
    17 Oct 2005
    Wow - that’s going to be a challenge! Might be worth making a jig?
  15. Goatee
    19 Apr 2015
    It’s got a cross over too, looking forward to the challenge.
  16. Goatee
    19 Apr 2015
    Jig made: [​IMG]
    I'm awaiting ATX Terminals and 24 pin ATX Connectors that are in the post, then I can start soldering connectors on and sticking everything in the connectors and hopefully making everything square and neat.
    Currently looks like this with the cable just stuck in:
    I have offset the power board (lined up with motherboard), so no cross over will be required (I think)
    The_Crapman likes this.
  17. Dr. Coin
    13 Sep 2013
    It's like you did not have enough heat pipes.
    Goatee likes this.
  18. Goatee
    19 Apr 2015
    You can never have enough heat pipes.
  19. Goatee
    19 Apr 2015
    The individual wires are quite difficult to straighten and keep straight.
    Not sure I like it, I might have to go with a thicker gauge of wire, feedback?
  20. Dr. Coin
    13 Sep 2013
    Several tips and tricks on the web for straitening wire. Home made jewellery folks are a good source.
    Additional you could build a custom wire comb for the horizontal run.
    Goatee and cobalt6700 like this.
