Other using netbook to download steam games?
Discussion in 'Software' started by total zombie, 17 Dec 2012.
  1. total zombie
    total zombie What's a Dremel?
    2 Nov 2009
    is it possible to use my netbook to download steam games? and then tranfer the files over to my gaming pc?
    some of the downloads are 13 - 21 gig and id rather not leave my gaming pc on all the the time its gona take to download, i have a really slow connection, i dont mind leaving the netbook on downloading.
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    sure you can. When you're finished downloading you backup the game, transfer the backup over to your gaming station and restore the backup.
  3. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Yes sure I do something similar with my server as it is much lower power. Don't use the useless steam backup system though, just copy the game files out of it's directory inside of steam directory. It's so much faster.
  4. total zombie
    2 Nov 2009
    ah cool! thanks! il get some downloads on the go.:thumb:
  5. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Im pretty sure you can download a game to a external disk somewhere.
  6. IvanIvanovich
    31 Aug 2008
    Only if you make a junction first, there is no way to select location of anything within steam, it always put everything inside steam directory.
  7. Snakko
    Snakko exterminate
    13 Dec 2009
    That's not correct anymore :)
    The latest version of Steam client (at least on Windows, cannot remember if it does the same thing on OS X too) allows you to create a new library on any available partition when you choose to install a game from your library
    e.g. from my steam:
    Anyway, @OP: as lysol already suggested, just download your games, and then move the steamapps folder from your netbook to the other PC, then restart Steam.
    The backup feature is useful only if you plan to backup your games on an external drive or optical discs (DVD-R or BD-R) but doing that on a netbook would be slow as hell, during the backup process, the files are compressed and the slow processor I suppose you've got on your netbook would slow down the whole process *a lot*
