Electronics using only some rails on a computer PSU
Discussion in 'Modding' started by nleahcim, 16 Aug 2005.
  1. nleahcim
    nleahcim What's a Dremel?
    22 Apr 2003
    Hi - I'm planning on using a old computer PSU I have laying around to power something I'm working on. I remember reading that to do so , besides shorting the green wire and a ground wire, you need to put a load on a certain rail for some reason or another. Does anybody know anything about this? Thanks!
  2. whypick1
    whypick1 The über-Pick
    17 Oct 2002
    Well, looking at the Antec PSU tester, it uses a 25w, 5.4ohm resistor, which I believe is on the +5v line, which would be about a 1A draw on it. If you want to do the same, you don't need a 25w, just something well over 5w (they probably chose 25w so it wouldn't be hot to the touch).
  3. nleahcim
    22 Apr 2003
    it's actually the 5V line that I'm interested in - I'll be drawing maybe 3A or so. Should that be OK? I'm keeping all the logic on a seperate supply just in case.
  4. hitman012
    hitman012 Minimodder
    6 May 2005
    The design guide for ATX 1.1 PSUs says the following loads are required:
    +3.3V - 0.3A
    +5V - 1A
    Your 3A draw easily covers the 5V minimum and you can usually get away without loading 3.3V at all, but if you're worried then just stick a 10R 5W resistor on the rail.
  5. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    The 5/3.3 and 12V rails balance each other, so to get stable voltages on 3.3 and 5V, you need to load 12V a little.
    I have experienced a drop of about 0,3V on the 5V line when 12V is not loaded down with a few hundred mA on several PSUs, both AT and ATX.
  6. mike047
    mike047 What's a Dremel?
    15 Jul 2005
    HI,
    I use an old PSU to power my breadboard.
    I just hooked an old small Hard drive to it.
    Works good:D
  7. One~Zero
    One~Zero What's a Dremel?
    9 Sep 2004
    I've also modded a psu for external use, and did put a 5 ohm, 25 watt resistor on the 5v line, and let me tell you, it still gets pretty hot!!! Voltages are a little off across all lines, so I'll probably throw another resistor in the 12v line to see if it bumps things up a bit. I didn't put anything on the 3.3v line.
