Electronics Using ribbon cable for...
Discussion in 'Modding' started by headala, 4 Aug 2006.
  1. headala
    headala What's a Dremel?
    9 Oct 2005
    ...USB and Firewire 400 connectors?
    The connectors on my mobo for additional USB2.0 and firewire will be covered up by my rad, without enough clearance even for the header plugs.
    Is it possible to wire ribbon cable (from a floppy cable) to the pins, and then that to the plugs? Will the voltage or current draw from the headers exceed the ribbon cable?
    Thanks for your help!
  2. kbates666
    kbates666 What's a Dremel?
    24 Jan 2006
    I wdont think there would be a problem using a ribbon cable. Just make sure that you double check your Wiring.
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    It's been done before in a fabulous work log with a custom metal case wrapped about an NF7-S. So it should be possible, just make sure to use the burlier 40 conductor cables - you might not get grounds between ever pin, but you do get thicker wire.
  4. headala
    9 Oct 2005
    Thanks for the help!
    So, 'beefier 40 conductor cable' wouldn't be floppy cable, then. What would be a source for this stuff? Old IDE cable?
    Thanks again!
  5. headala
    9 Oct 2005
    BTW, you got a link for that log or a name of the project?
    I'd like to take a look. I'm a little sad that I'm not the first to do it :(
  6. Gman22
    Gman22 What's a Dremel?
    15 May 2004
    Yep, old IDE cable is the stuff he's talking about.
  7. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    Floppy cables should be a heavy gauge also, I think he meant just stay away from the newer 80 conductor IDE cables.
  8. Tulatin
    16 Oct 2003
  9. bender386
    bender386 What's a Dremel?
    5 Jan 2006
    i thought that usb was balanced like cat5 so you should use twisted cable?
  10. Firehed
    15 Feb 2004
    I've done it before, at least with USB, with no adverse effects. I had my firewire rigged up as well, but I never use it, so I have no idea if it was problematic.
  11. bender386
    5 Jan 2006
    it would probly be a problem in a high interferance area
