Photos Using the full potential of my SR2
Discussion in 'General' started by BennieboyUK, 3 Jan 2012.
  1. BennieboyUK
    BennieboyUK CPC Folder of the Month Sep 2011
    24 Nov 2010
    Haha not just yet, he getting a Q6700, with 4gb ram and an ATi 4550... It's just sitting in the attic not in use so might as well put it to use. We have media in the bedroom and lounge so he is familiar with the interface.
    He better like it, I don't share my man cave with many!
  2. lcdguy
    lcdguy Minimodder
    25 May 2004
    something similar happend to me recently. My 2 yearold niece came over and saw me playing NFS:HP with my G25 Wheel and wanted to try it. So sat her infront of wheel. She drove while i worked the pedals. Got to start them at some point :D.
  3. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Tried that, clever bugger moved a chair to open the flaming door handle :grr::lol:
  4. BennieboyUK
    24 Nov 2010
    Made a start man cave improvements today :D
    Getting all the cables run, brackets mounted, then ceiling needs a skim, painting and new carpet - but lets get the fun stuff done first:
    TV in "test"
    Men can do two things at once, Windows Updates + Wall smashing...
    Bracket holes done, cable hole created, now to find the bottom...
    Bottom hole as small as possible, as I only have 85mm skirt - horrid original stuff. when decorating is done it will be replaced with 140mm, I will then route the cable fully behind the skirt. - much like the power, and Cat5 that is in the pic too.
    View from the sofa
    Finished for now
  5. t4n6o
    t4n6o You know when you've been tangoed
    16 Aug 2011
    just a bit of advice when you pit the skiring on:
    I used to be an electrician and if you run the power in the same containmnent as the cat5e then you are likley to get interfearence due to the magnetic fields they produce, can I suggest daido skirting rail.
    this stuff
    What it looks like on a floorhttp://www.mapfre.com/fundacion/html/revistas/seguridad/n120/img/art_2_14.jpg
