Graphics using three video cards
Discussion in 'Hardware' started by Just Me, 11 Feb 2007.
  1. Just Me
    Just Me What's a Dremel?
    11 Feb 2007
    Hi all ,
    I am trying to use three video cards , with three monitors on one system running XP Pro.
    First card is a Radeon 9200SE (AGP)(128 Mb)
    Second ia a Matrix Graphics Mystique (PCI)(64 Mb)
    Third is a S3 Trio 32/54 (PCI)(64 Mb)
    The latter two cards being quite old , but still in good working order.
    All three cards work perfectly , but when in the same system only the first two will work , with the S3 trio showing as having a problem and has no resources attached to it.Updating driver etc. does not solve the problem.
    Any suggestions?
    Thanks in advance.
  2. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Sounds like you are out of IRQ's (resources) to assign the card so you wont be able to run 3 video cards on your current motherboard. I would suggest getting a nice PCI card with 2 monitor outs. But your agp 9200SE should have dual monitor outs, so use those 2 on the one card with the sweet matrox Mystique and you will get 3 monitors.
  3. Just Me
    11 Feb 2007
    Belive it or not , that never even crossed my mind.... Now I feel like an idiot....lol
    Cheers
  4. keith_j_snyder2
    keith_j_snyder2 What's a Dremel?
    22 Apr 2006
    Well i dont think u might be able run these cards together.This is like X-firing SLI.
  5. nimbu
    nimbu Modder
    28 Nov 2002
    Actually its not X-firing SLI. As the cards are not being used to spread the work load. Each card is handling output to its own specific monitor.
    Its just that the card / driver needs to be able to support multiple displays. Back in the day I can remember experimenting very heavily, and found that S3 based cards are very very fenicity when trying to do this. I had no problems running multiple matrox and TNT PCI cards in one machine.
  6. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    if you are running out of IRQ's then go into the bios and disable everything you don't use like paralel ports etc.
  7. JazX101
    JazX101 What's a Dremel?
    27 Jun 2004
    Lo!
    Why not find a slightly better AGP card, like the £20 i spent on a FX5200 off good ol' flee-bay, and find something that will dual head happily?? my FX did perfectly well running dual monitors, even when running games on the primary.
    Jaz_knos
