Modding Using two power supply as one
Discussion in 'Modding' started by Edwardyh, 24 Sep 2002.
  1. Edwardyh
    Edwardyh What's a Dremel?
    24 Sep 2002
    I was just wondering if i had two power supply (300 or 400 watts) is there a way to connect them together (like when i hit the power button it turns on both power supply at once)??
  2. GiGo
    GiGo was once a nerd.....
    12 May 2002
    Yes you can. Macroman should be able to help you there.
    Macroman, get your ass over here now, someone needs you!
  3. Moo
    Moo What's a Dremel?
    19 Aug 2002
  4. Edwardyh
    24 Sep 2002
    thanks... guys will check out the links when i get home form school....
    P.S. thanks alot!
  5. Seth
    Seth What's a Dremel?
    14 Mar 2002
    gigo that was a little disrespectful if you ask me, but that is prolly not the way it was intended.
  6. m00min
    m00min What's a Dremel?
    6 Jul 2002
    me and a tommy successfully have achived the dual psu mod
    magic :D
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Prob a stoopid question but, What do you use two PSU's for?
  8. m00min
    6 Jul 2002
    powering extra hdd's, cathodes etc you can only power soo many bl00 leds off 1 psu :rolleyes: :eyebrow:
  9. thepedster
    thepedster What's a Dremel?
    5 Jun 2001
    by the looks of it that PC doesnt really need twin PSU's,
    unless there both pretty low power, its a slot Athlon or P3 so not a hungry munster really,
    ocuk sell a plug and play solution, but making it yourself is more rewarding
  10. ::Dawg::
    ::Dawg:: What's a Dremel?
    14 Mar 2002
    Why not just buy a higher wattage power supply then?
  11. m00min
    6 Jul 2002
    you tards, no offence the idea was for the fun of modding and total unpractical :wallbash: :wallbash:
  12. Lazy
    Lazy Meow?
    13 Nov 2001
    you can buy a little gadjet from overclockers.co.uk to power on 2 psu's at once :)
  13. Atomic
    Atomic Gerwaff
    6 May 2002
    Thats why i was asking. Im powering about the same amount of stuff as that on one PSU... but thats a 500W.
  14. Edwardyh
    24 Sep 2002
    thanks guys for the help... but i have one more other question.. will i still have to use 2 Switches?? ( if so: is there i way i can only use one switch???)
  15. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    Sure... Make the first one (attached to the MOBO) to power a 12v relay. Hook up the Green and White wires of the MOBO connector on the second PSU to the NO contacts of the relay.
    Voila, Dual Power (make sure you have a GOOD LOAD on the 12V side of the second PSU, or you WILL burn it out)
    This will allow you to use one power supply to turn on the other, all with one switch. nuff sed?
  16. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    cool mod;)
    only got a 300W and I got so much stuff on it... burner/dvd/3fans/4 ccs/etc... might be near limit but it works:D
    but it's a great idea when having small psu... no need to buy a bigger one:lol:
  17. Edwardyh
    24 Sep 2002
  18. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
  19. Pflumingo
    17 Jul 2002
    Does the EXACT same thing I suggested, just costs about $10.00 more. It's up to you... But yes that will work... By the way, you will have a .12 second lag time before the second PSU will kick on, but that shouldn't be a problem, still powers on before post.
    P.S. the suggestion I suggested will work with an old AT power supply as well... Use a double pole relay, and kick the 120V switch from the at psu with it. Works a treat as well, and utilizes my old MAMMOTH AT power supply, I use it for my pump and a pelt.
  20. :: kna ::
    :: kna :: POCOYO! Moderator
    15 Mar 2001
    Very neat, but £15 + £10 delivery.. expensive for something you could probably make yourself.
