using widescreen tv as second monitor - need help
Discussion in 'Tech Support' started by chrisb2e9, 4 Jul 2008.
  1. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    hello, I am trying to use my second tv as a second monitor. So far i'm pretty happy with it but the resolution on the tv (1024x768) is not a widescreen one. the tv can stretch it out so the entire screen is filled but then I lose part off the bottom. I can stop the tv from stretching it out but then its a smaller image on the screen. I only have 2 options when I try to set the resolution, 800*600 and the 1024x768. anyone know of a way that I can get a full screen image without losing part of it off the bottom of the screen?
  2. woodshop
    woodshop UnSeenly
    14 Oct 2003
    check your tv again and look for a "stretch" mode not "zoom", stretch won't cut off the picture but may mke everything look fat..
    The other option is to try using a DVI->HDMI cable and the latest drivers, if your lucky the tv will be detected and give you 720p/1080p options. OR there is an app out there (name escapes me) that lets you tweak (carefully) the cards setting for the port to get a 720p image, along with refresh, over under scan and many other things that could hose your tv if done wrong. and the tv don't have sanity checks.
  3. chrisb2e9
    18 Jun 2007
    I think I remember seeing in the manual for the tv not to use a hdmi signal from a pc. but I could be mistaken or maybe i read it wrong. i'll take another look if I can find it again.
    Thanks for the help.
  4. tk421
    tk421 Idiot.
    15 Jan 2002
    what video card & tv?
    i had a hell of a time getting our 2 32" lcd's at work running off of intel integrated graphics over vga using dual dvi to dvi/vga splitters. stupid dell lunchbox pcs.
    at home, i just use the ATI driver to force 720p and it's fine either over vga or dvi.
  5. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    I think Rivatuner will let you alter resolution and such if you have an nVidia card.
  6. chrisb2e9
    18 Jun 2007
    its an ati 4850 and a toshiba 32hlv66
    I found a setting in the tv that lets me adjust the height of the display. I almost have the full image now but there is still some cut off.
    how do you use the ati driver to force 720p?
