Scratch Build – Complete USS-Dragon-1
Discussion in 'Project Logs' started by random2k4, 7 Mar 2017.
  1. random2k4
    random2k4 Modder
    11 Aug 2015
    Hi everyone,
    its Stefan from RandomDesign again.
    This time I want to present my latest project.
    But first, the hardware list:
    Mobo: MSI Z270 Gaming M7
    VGA: MSI 980Ti Lightning
    CPU: Intel I7 6700K
    Memory: HyperX Predator 4x4GB 3000Mhz
    SSD: HyperX Savage 240GB
    PSU: Enermax Revolution 650W
    Fan: Enermax D.F. Vegas Single
    Water cooling: bitspower
    The concept:
    The design of this mod is based on the "Type 9" shuttle from the TV series Star Trek Voyager.
    The shape for the basic construction is made from styrofoam. Therefore, I glued several layers together to get the right hight.
    The rough shape was then cut with a knife.
    The finer work was done with a rasp. At the end I used a sanding sponge to smooth out rhe surface.
  2. Cheapskate
    13 May 2007
    Taking a different approach this time, I see. :D
  3. random2k4
    random2k4 Modder
    11 Aug 2015
    everytime trying to learn something new :)
  4. random2k4
    random2k4 Modder
    11 Aug 2015
    After the basic shape was done I applied multiple layers of glass fiber and epoxy resin.
    It is important to use epoxy here and not polyester resin. polyester resin will jsut destroy the foam core.
    After that was cured. Body filler was used to cover the entire body.
    I also gave it a rough sandind and repeated the step until the surface was even and smooth.
  5. random2k4
    random2k4 Modder
    11 Aug 2015
    Next, I added some details on the body.
    Therefore, I masked an area that should be highlighted with some rubberfoam and filled it with body filler.
    Afterwards, I removed the rubberfoam, sanded the body and applied a layer of sprayfiller.
    Then, I filled smaller gaps to make the surface as smooth as possible.
    After this was done, I cut the body for creating the opening.
    I removed the styrofoam core with some aceton.
    I marked the position of the windows and cut them out.
  6. David
    7 Apr 2009
    Ooh, I like.
    Subbed!
  7. random2k4
    random2k4 Modder
    11 Aug 2015
    Next, I installed the opening system. The hinges were mounted to a wooden block and then attached to the body.
    I installed two wooden blocks, that will later hold the plate for the hardware.
    To close the gaps between the lid and body, I covered one side with tape and applied body filler.
    That way both edges will fit perfectly.
    Then, I cut the holes for the fans in the back.
    On the bottom side, I included the holes for the fans of the radiator as well as the PSU.
    I alo cut an opening which I will be using later to isntall the cables etc.
    In the top I drilled holes for the water tank that will be installed directly behind the opening mechanism.
  8. Hukkel
    Hukkel James' minion
    20 Dec 2012
    That is looking spectacular man :)
  9. kim
    kim hardware addict
    10 Jan 2016
    spectacular is the word indeed, it took shape so fast, it's already so close to the result in a few steps, when I first looked up the styrofoam base, and the last pic...:clap::clap::clap:
  10. argun
    argun What's a Dremel?
    13 Mar 2017
    Remarkable.
  11. random2k4
    random2k4 Modder
    11 Aug 2015
    Thanks guys.
    And up we go with the next update.
    I cut a wooden board into shape so that is fits perfectly inside the mod.
    Then the hardware was placed to see if the layout is good looking.
    Holes were made, for the water cooling and cable.
    To keep it simple, the sufrace was covered with black foile. This will ad a bit more contrast later on with the silver fittings and blue
    cooling liquid.
    For the windows, I cut acrylic glas into shape and attached it wit cylinder head screws.
  12. random2k4
    random2k4 Modder
    11 Aug 2015
    I painted the entire body in a grey color. I went for a darker color then in the original,
    that way I can highlight some areas more easily later one.
    For the illimunation, I glued two RGB-stripes into place.
    Unfortunately, I missed some pictures in the making process of the engiens.
    For them, I first made a 3D model and printed it. After sanding, all the parts were glued together.
    I included pieces of acrylic glass, that will be illuminated not only with LEDs but also with
    a running light effect.
  13. ADmodz
    ADmodz Go hard or Go home
    16 Oct 2016
    Craftsmanship right there
  14. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Really cool build! I can't wait to see the finished product!
  15. Cristianodanna mod
    Cristianodanna mod Minimodder
    16 Dec 2016
  16. MellowMods
    MellowMods What's a Dremel?
    17 Jan 2017
    Dude seriously? How cool is this!? I'm actually watching the series again right now.
  17. random2k4
    random2k4 Modder
    11 Aug 2015
    Thanks to all of you. This really kept me motivated :D
    Haha, I just watched all seasons recently too.
    And now for the last update before the final pictures.
    I started off by installing the waterblocks for the CPU and Memory.
    The GPU should be placed horizontal above the mainboard. Therefore, I built a small mounting that holds the graphics card.
    Before placing the board with the installed hardware back into the mod, I installed all the needed acrylic tubings.
    Finally, I made some extensions for the cables and sleeved them.
  18. GeneralFun
    GeneralFun Lurker with tools
    24 Feb 2014
    Stellar work.
    Wait.... Stellar?
    Star?
    Star ship?
    Stellar?
    Oh good God, that was bad! Your work is great though. Keep it up
  19. random2k4
    random2k4 Modder
    11 Aug 2015
    And here are the final pictures. Was a fun little project. Hope you liked it too :D
    Made also a video showing the various working phases:
  20. kim
    kim hardware addict
    10 Jan 2016
    the USS dragon is really great, but your video is my favourite part, it shows how you are mastering all those modding techniques with an amazing accuracy, your skills are endless, and your projects are always out of common and gives me a lot pleasure to follow ...
