Windows ut2k4 and logitech problem
Discussion in 'Gaming' started by Tribal Dragon, 26 Apr 2004.
  1. Tribal Dragon
    Tribal Dragon Insomniac modder!
    17 May 2002
    I bought ut2k4 after playing the demo for a while and now I have a problem...
    I have a logitech mx duo (wireless mx500 and wireless elite keyboard) and I suffer terrible lag...
    the keyboard is horribly laggy (I press w then press d but continue for a sec or two foward then goes right... if it goes right..) and sometimes the fire buttons just continue to be on like if they were stuck... anyways the game is unplayable... got latest version of iTouch, tried with and without it, tried to put the keyboard and mouse at 6 inches of the receiver, nothing works...
    now every other games works nice except that one... and I don't want to buy corded mouse and keyboard just to play a game...
    anyone experienced that or know what might causing the prob because I'm clueless....
    (using XP pro sp1 and the mx duo is plugged in PS2)
    thx for your time
  2. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    have the logitec cordless set below yours and having no problems... Have you tried it in USB? Are you using an encryped channel?
  3. MikeTitan
    MikeTitan Ling Ling: 273 Battle Points
    4 Mar 2003
    Im having a problem right now with my wireless logitech elite. All the media buttons don't do what they should. Play button raises sound and such. Not sure why. I think its cause of the batteries since they haven't been changed in a year. But when i play UT2k4 When i am moving around I can't strafe and go foward anymore. This means when Im using trying to move around its exceedingly hard to move around.
  4. fallenSaint
    fallenSaint What's a Dremel?
    25 Apr 2004
    When using logitechs stuff its very important to make sure you have the most current logitech drivers as well as windows updates Ive had several issues in the past getting all my buttons to operate in game and logitech is usally good at getting an update out to fix such issues. Beyond that not sure what would cause such lag in game. Im currently using the diNovo set and they respond quite nicely in game but when I had the elite duo they ran bad til the update drivers.
  5. Tribal Dragon
    17 May 2002
    just used ps2 connections and encrypted channel. hum maybe encrypted channel would do that? I'm gonna give it a try ^^
