Windows uTorrent Keeps Freezing
Discussion in 'Tech Support' started by isaac12345, 4 May 2014.
  1. isaac12345
    isaac12345 What's a Dremel?
    20 Jul 2008
    Hi,
    I have recently started experiencing random freezes in utorrent that has significantly increased the amount of time that my downloads take to complete and hence the amount of electricity being spent. It keeps freezing and then coming back to normal. Thinking that it was because of corrupted files, as a result of power cuts in my area, I reinstalled it only to find that it didnt help. I had a look at the windows 7 resource monitor to see what happens when it has frozen. There is no increase in CPU usage but the process is highlighted in red as 'not responding'. I cant seem to be able to figure this out and dont want to install another client as I am most acquainted with utorrent. Could you please help me out? It would be much appreciated. :)
  2. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    I'm going to presume your not downloading Linux ISO's so really your saving quite a bit of money. :)
  3. loftie
    loftie Modder
    14 Feb 2009
    You're probably best on any utorrent forums tbh. Roll back to an earlier version. Remove any torrents that have completed. Are you saving them all to the same drive? It could be the drive acting up if you are.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    it came with a free eyepatch and parrot
  5. erratum1
    erratum1 What's a Dremel?
    30 Apr 2009
    I still use an old version (2.2.1) didn't see any point in updating if it's not broke.........
  6. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Is that parrot version 2.2.1
    I hear they just wont shut up ;)
  7. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    Keep an eye on the disc usage readout at the bottom of your UTorrent window. I recall (when I used ut many years ago) seeing that hit 100% frequently and causing all sorts of mayhem. Can't remember the fix but it didn't take me long to google it.
