Windows uTorrent replacement
Discussion in 'Software' started by silk186, 6 Mar 2015.
  1. silk186
    silk186 Derp
    1 Dec 2014
    running windows 10 and I'm getting tired of uTorrent. First all the advertising now this BS with Epic Scale. What is a good alternative to uTorrent. Preferable one that can handle labels properly (uTorrent doesn't) so that torrents with different labels will be moved to different folders upon completion.
  2. loftie
    loftie Modder
    14 Feb 2009
    Can you not just turn off the adverts in the advanced settings or have they removed that now?
  3. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
  4. ripmax
    ripmax Minimodder
    8 Apr 2010
    qBittorrent and deluge are the are the most popular currently.
  5. Isitari
    Isitari Minimodder
    6 May 2009
    Try qbittorrent. Not sure if it handles labels though.
  6. RedFlames
    23 Apr 2009
    The 'Bittorrent' client is just uTorrent in a different hat, underneath they're the same
    can't attest to their individual usefulness as it's a while since i've used any of them...
    Vuze [needs java iirc]
    qBittorent
    Deluge
    Tixati
    EDIT: IIRC Opera [the browser] could d/l torrents, dunno if it still can... and i'm told there's a windows port of Transmission available too...
  7. Shirty
    18 Apr 1982
    I use Deluge (for entirely legal purposes of course :worried:). It's like uTorrent was before the crap arrived.
  8. RedFlames
    23 Apr 2009
    Vuze iirc handles RSS torrents [like 'World of *' game updates] the best of that list, but from what i remember it's almost as bad as uTorrent for ads...
  9. silk186
    silk186 Derp
    1 Dec 2014
    yes, I can disable ads as I have. But they are putting more and more crap into the software. It is getting more annoying to install software like this as it really tries to trick you into installing extra crap and my have stated that this bitcoin mining software appeared after an update without asking permission to install. I don't want to suppor uTorrent any longer.
  10. David
    7 Apr 2009
    Don't forget to fill out the exit survey when you uninstall it. ;)
  11. wolfticket
    19 Apr 2008
    Personally I wouldn't trust anything not open source.
  12. loftie
    loftie Modder
    14 Feb 2009
    I can understand that, I stopped updating uTorrent, it's on 3.3. Having a quick look at the website, and seeing the pro subscription I'm glad i've not updated.
  13. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    nothing useful to add so saying nothing, lol
  14. Ljs
    Ljs Modder
    4 Sep 2009
    utorrent died years ago.
    qbittorent all the way (light, simple, no crap).
  15. RedFlames
    23 Apr 2009
    Tixati doesn't require an install and is at or around 10MB [depending on whether you go for 32 or 64 bit]. Yes that's 10x the size of uTorrent [6x based on more recent versions] but in the grand scheme of things I wouldn't lose much sleep over it.
  16. silk186
    silk186 Derp
    1 Dec 2014
    It is difficult to find something feature rich with a nice UI. Preferably that plays nice with sickrage and iptorrents... i guess the best choice is an older version of uTorrent. It just bothers me running software that is not the most up-to-date version.
  17. Icy EyeG
    Icy EyeG Controlled by Eyebrow Powers™
    23 Jul 2007
    That's because they are cross-platform. This means that on Windows they need to ship with toolkits. On Linux the installer is significantly smaller (qbittorrent deb is 2 Mb). If there was a win32 port of qbittorrent, it'd be significantly smaller as well.
    On Windows why don't you use qBittorrent Portable? And sure, it occupies 15 Mb, but does that really make a difference nowadays?
    I don't know anything about iptorrents, but keep an eye on this for sickrage.
  18. elise_s1
    elise_s1 What's a Dremel?
    26 Jan 2015
    Cannot agree more. I spend ages to install drivers with "have disk" procedure to avoid the bloatware. And what about PDF reader?
    Engraved using an ancient artifact
  19. sourdough
    sourdough Minimodder
    17 Sep 2010
    Tixati is lightweight and easy to use.
  20. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Sumatra PDF
    /thread derail.
