Modding UTV Cooling...
Discussion in 'Modding' started by KinGvsKinG, 26 Jun 2003.
  1. KinGvsKinG
    KinGvsKinG What's a Dremel?
    20 Apr 2003
  2. bard
    bard Modding isn't what it used to be
    8 Mar 2003
    So the new HD generates that much more heat? I suppose you have one fan blowing out and one sucking in? Do you have a temp monitor in there so that you can see the temp difference? Isn't the unit's OS located on the HD you removed too? What makes the fans so smart btw? :D
    Ok, I admit it, I ask alot of questions. Seriously, I look like this all the time: :confused:
  3. jetsetjimbo
    jetsetjimbo Up-up and away
    19 Feb 2003
    That's sweet! Should really cut those temps... Are the fans being powered of a molex splitter on the h/d power connection?
    Bard - I believe the fans are 'smart' as they have thermal sensors so speed up/down automatically depending on the temp IRC.
