Modding UV love...
Discussion in 'Modding' started by KniFenForK, 22 Oct 2003.
  1. KniFenForK
    KniFenForK Minimodder
    11 Oct 2002
    Finally my kit arrived, so here it is installed! Spec in sig:
    At night:
    Insides:
    Nice glowing IDE cables
    Blowhole at the top, looking into the res, used an 60mm-80mm fan adapter to attach the res to the blowhole :D
    And by day:
    What do you think?
    Thanks
  2. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    pretty pimp dude :thumb:
  3. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    Very pimp indeed. I cant wait for mine to be done. :sigh:
  4. lazychook
    lazychook What's a Dremel?
    21 Oct 2003
    yo KniFenForK does your mud flap girl have a MASSIVE square nipple? sure as hell looks like it in the pictures...unless they are just freak coincidences... :eeek: ...in both photos, coz damm!!!
    haha, sweet mod btw :thumb: love the nice mix of colours, they look really good through the water cooling pipes!
    so do we get to see whats happening behind that front pannel? anything intresitng?! :lol:
    POST SOME MORE PICS!!! :rock:
  5. Kasius
    Kasius Bringin' the dremolition
    16 May 2003
    Just brought 2 akasa UV CCFS,
    Being the fact i have not had all my new equipment delivered yet i'm not sure as to how they will preform incase, however i'm not overly impressed with the brightness outside the case... we will have to see.. :worried:
  6. SJP
    SJP What's a Dremel?
    12 Feb 2003
    Looking good :rock:
    In my experience, those acrylic-tubes tend to filter-out a lot of the UV, leaving a fair amount of visible light, and little UV. Removing the outer tube (they're usually glued at either end to the square blocks) increases the proportion of UV significantly.
  7. KniFenForK
    11 Oct 2002
    Thanks for all the comments!
    Some more images, as requested ;)
    Inside (with blue and red cathode on) (the stock nb cooler is going!)
    Inside with flash on:
    Rad in drivebay:
    Res, held up by fan converter: :D
  8. Supercool
    Supercool Gone.
    31 May 2003
    :eeek: the hose coming out of your res in that last pic looks like a sharp bend and a kink, you should probably try straightening it a bit.
    Lookin' good :thumb:
  9. KniFenForK
    11 Oct 2002
    Yea it does look quite bad in the photo, must of been the angle, as its only slightly kinked.
    Thanks
  10. Paperbag
    Paperbag What's a Dremel?
    28 Jul 2003
    Ooh, that's so nice. Probably the most intense UV-glow I've seen. :rock:
  11. lambbuster
    lambbuster What's a Dremel?
    8 Oct 2003
    i take it that the radiator is in one of the bays?
    What are you using to cool the radiator?
    Phil
  12. KniFenForK
    11 Oct 2002
    Yea it is in the bay, seems ok so far, temps are 35C idle, which is pretty good considering everything is internal, so the case is hotter.
    I just have a 120mm YS-Tech fan on the rad, running at 7v, so the system is quiet!
    Thanks
  13. lambbuster
    8 Oct 2003
    thanks for the info. what is the radiator? black ice?
    Also, what tubing?
    I have a dangerden setup, but what to modify it so you can't see the rad etc.
    Phil
  14. KniFenForK
    11 Oct 2002
    Its a thermochill 120.1, basically a bix ;)
    Im using silicon tubing at the moment, but am keen on replacing it as it kinks easier.
    Thanks
  15. Zeke_D
    Zeke_D What's a Dremel?
    1 Oct 2003
    Beautiful!!!
    I like UV too. This glow powder is AWESOME!! Try some.. really.. http://www.unitednuclear.com/glow.htm
    The uranium marbles glow crazy like under UV as well. Get 100 for $15 on Ebay. I have 6 uranium marbles and have been tempted to do a whole panel of UV marbles on a PC with UV LEDs.
    I likes the nipples. :thumb:
  16. KniFenForK
    11 Oct 2002
    Thanks, but that powder only lasts 12 hours?
  17. BioSniper
    BioSniper Minimodder
    5 Feb 2002
    mmmmm.. UV goodness :thumb:
  18. mrplow
    5 Sep 2001
    glows for 12 hours after exposure to light.
  19. KniFenForK
    11 Oct 2002
    O right, nice!
  20. slyf0z_87
    slyf0z_87 What's a Dremel?
    3 Sep 2003
    oh wicked!!
    i'm gonna get me some of that!!
