Modding uv paint
Discussion in 'Modding' started by tater salad, 2 Feb 2005.
  1. tater salad
    tater salad What's a Dremel?
    26 Nov 2004
  2. magicpixel
    magicpixel What's a Dremel?
    11 May 2004
    Hi, yeah I've used it. Both Blue and red.
    I fond the red to be the brighter of the 2.
    They're not exactly 'clear coat', they give more a 'misty' finish.
    The great thing about them is that if you don't like it or get bored of it, you can rub it off with a wet cloth.
  3. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    Dont know, that's kinda bad when you want to clean your window :eyebrow:
  4. Lost.Soul
    Lost.Soul What's a Dremel?
    26 Oct 2004
    Simply pain the inner side of window? :naughty:
  5. magicpixel
    11 May 2004
    Agreed, or don't let the muck gather too much, give it a dusting every so often.
    Besides, the paint needs quite a rubbing to remove it. It wont come off if you go over it softly with 'damp' cloth.
  6. tater salad
    26 Nov 2004
    from what ive read, you have to use amonia.
    my mom wont pay for this with a creditcard, so i gotta find a way to pay with cash or check.
  7. magicpixel
    11 May 2004
    Actually you are right. It also comes off with water, trust me.
    Last time I checked, frozencpu only acepts(sp?) PayPal. No CC, money orders and so on.
    Look around, you'll 'prob find it elsewhere.
  8. Kobalt
    26 Aug 2003
    Or find someone who has PayPal and arrange it with him
  9. TroubledMind
    TroubledMind What's a Dremel?
    9 Aug 2004
    As a reply to the stuff you have mentioned, I have used that before but only on my walls because I have 2 4foot UV cold cathodes. For inside of my case I use a different UV paint I bought from Spencer's gifts which I actually put on the components and chips.
  10. Athlon3400
    Athlon3400 What's a Dremel?
    6 Dec 2004
    I have, it gets all flaky when it heats up, and flies off aorund your case
  11. TroubledMind
    9 Aug 2004
    that's if you gob it on, you need to use thin layers and it stays on just fine.
    been on for about two years and I have had no problems so far.
    Stil on the motherboard and the video card, even the heatsink that heats up it is still on.
  12. tater salad
    26 Nov 2004
    so u got that from spencers? how much was it?
  13. TroubledMind
    9 Aug 2004
    I don't remember but something like 6 bucks comes in a bunch of different colors.
    all those bright colors to the right.
    the only thing is it is not clear under normal light, but it still looks good even with out UV lights on.
    Ohh by the way I am in no way responsible if you fry anything with the paint :D
  14. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Lol, I have that same paint kit from spencers!
    I've been buying things from frozencpu for 2-3 years now, and not once have I had to use paypal, so I've no clue what you're all on about.
    And as far as the spray uv paint, no its not clear, yes it will come off with water, multiple coats are good if you dont have the clear coat. Heres something I did with some of the blue:
  15. magicpixel
    11 May 2004
    It could be an oversees thing. I'm in Europe and only have a PayPal option over at frozencpu.
  16. tater salad
    26 Nov 2004
    i only get the paypal or credit card, and i need to pay with cash check or moneyorder.
  17. TroubledMind
    9 Aug 2004
    Yeah shroom that paint kit is really nice. I think I am actually going to clean off that old motherboard so I can put it in a smaller case with a blue and purple uv color scheme and I have another board that I will paint for my current case with thre green fans.
  18. magicpixel
    11 May 2004
    Get in touch with Mark mark@frozencpu.com or better yet, give him a call and maybe work something out.
  19. shroom
    6 Aug 2003
    By the way, anyone interested in that paint kit, there is a down side. When it gets hot, it cracks. So unless you put multiple layers on chipsets etc, alot of it will blow off in the airflow.
