Case Mod - In Progress V1000 - Smal stuff [update: 28-10-2008]
Discussion in 'Project Logs' started by luis_pedro_Sato, 17 Jan 2008.
  1. luis_pedro_Sato
    luis_pedro_Sato Minimodder
    29 Nov 2004
    Hello every one.
    This is a case i recently bought from a friend of mine.
    Every one knows this case so there's no need for introduction
    A little bit durty
    A 240 rad hole.
    The screws from the psu plate broken
    1 Step - Cleaning
    Removing the interior
    Board tray and dvd drives holder
    2 Step - Modding
    Tray
    Closer look at the screws
    3 Step - Painting
    Finished painting
  2. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    My first reaction when seeing the overall condition of the case was "Poor case", but the white looks quite good - glad you painted it. Will keep an eye on this. :)
  3. luis_pedro_Sato
    29 Nov 2004
    4 Step - Assembling
    PSU plate whit M4 screws
    Bay covers
    Case closed
    WC :
    Cuted screws
    Rad and suport
  4. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    The White and Black look really suits that case, nice modding!
  5. Brett89
    Brett89 Minimodder
    15 Dec 2005
    Looks awesome, very nice paint.
  6. luis_pedro_Sato
    29 Nov 2004
    4 Step - Continued
    Reservation Danger Den.
    Lian li simbol
    PSU plate
  7. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    white and black looks good. cant wait to see the internals.
  8. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    was the removal of the internals fairly easy? many rivets to drill? been meaning to strip my v1000 down to sort the divider plate out.
  9. luis_pedro_Sato
    29 Nov 2004
    Its very easy to remove, about 15 rivets to drill if you want to remove the all structure.
    Go for it
  10. Burnout21
    9 Sep 2005
    wouldn't you agree the lian really didn't consider wiring for these bad boys. the long hole in the divider is just poor to run cables threw as it produces a rats nest of wires! hacking out some of the mobo tray gives great clearence if you want the smooth clean look.
    also did i spy a danger den fill port in the windowed side panel. towards the front 120mm fan....
  11. luis_pedro_Sato
    29 Nov 2004
    Its a blasfami to heart a Lian li case :nono:
    The first thing that i think when i am working on a lian li its, don't scratch :dremel: and do it good at the first time. There no second chance.
    The hole you see on the side is going to be a RESET button, but i am not sure it will fit bescausa of a 120 rad there.
    I made some changing s on the inside, today or tomorrow i will take some pics from the interior.
  12. Burnout21
    9 Sep 2005
    i have never hurt a lian li. i mounted a single 120mm fan in the top of mine to help cool my 8800GTS. and cut some nice holes to pass cable threw.
  13. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    Looking forward to seeing what you do with this, I've got the same case, planning to put a 240 rad in the bottom where the hard drive racks are, d'ya reckon it would get enough air (so to speak) from underneath the case? (apoligies for slight hijack)
  14. luis_pedro_Sato
    29 Nov 2004
    Theoretically you will get better performance because all the cold hair will be at the bottom of the case (Hot hair is light tha the cold), you just have to chose if your going to blow the wind agaisnt the rad or extract the ar off the rad.
    By the way, its a great ideia yours, just don´t cut a 240 rad hole on the case. Put a fan on the front, 2 on the rad and some crews to make some hight on the case, and the air will flow from the front to the rear, (it will come out at the psu fan)
  15. Angleus
    28 Nov 2007
    Cheers man, so do you mean raise the rad inside the case so its off the case floor? Drawing air in the small holes in the bottom of the case and the front intake?
  16. robyholmes
    robyholmes I'm under your desk...
    17 Jan 2008
    I have just got a V1100S Plus II case. Then Lian Li case are great! But i don't think i have enough skill to paint or mod mine i am to scared. Lol, looks great in white tho! Good job
  17. luis_pedro_Sato
    29 Nov 2004
    Yes, the rad of the floor, about 1~1,5 cm, and the fans on top of the rad, pushing the air down.
  18. luis_pedro_Sato
    29 Nov 2004
    Interior update
    Small rectangular hole for the usb, and fans wires.
    Hole for the 24 pin connector to the board
    120 Rad and fan
  19. Angleus
    28 Nov 2007
    Oh ok I get ya, yeah tbhat makes sense, I hadn't thought of it like that, cheers mate!
    Well done on the wire managment btw, keep it up :thumb:
  20. Handon
    Handon What's a Dremel?
    10 Feb 2007
    Like it ;-)
    Nice paintjob on that case and nice case.
    Like to see more of that
