Modding vacuum molding / forming
Discussion in 'Modding' started by theagent, 11 Oct 2004.
  1. theagent
    theagent What's a Dremel?
    4 Nov 2003
    those of you with links to good vacuum forming guides, post them here!
    if you've completed the guides, post comments about the finished product.
    http://www.armorama.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=404
    thats the best one i have
    i'm looking to mod a controller [basically add a clay or something to form it to my hand, then vacuum form plastic over it. i've considered heat issues, but now i need to build the machine]
    also what kind of plastic do you use?
  2. grodot
    grodot What's a Dremel?
    21 Sep 2004
    Vacuumania!
    I dunno if you've seen these but Google coughed up tonnes, keyword: "diy"/"home-made thermoformer" OR "home-made vacuum form"/"ing".
    http://www.robots.ox.ac.uk/~wmayol/resources/nacipobre/
    http://www.tki.org.nz/r/technology/curriculum/rsnz/vacuum_e.php
    http://members.aol.com/GCGassaway/vacuform.htm
    http://www.studiocreations.com/howto/vacuumtable/
    http://marvin3m.com/vacuum/
    http://www.alstevens.com/ventriloquism/vacuum.html
    The materials range from "styrene" (probably polystyrene) sheet, to acrylic in various gauges, although I remember always using acrylic in secondary school.
    If you use acrylic, then color would be another dimension that you could factor in. Imagine a custom-formed controller casing in a UV hue with a LED stuck up its side (if that's your thing).
    Take care when heating the sheet, use gloves, open all windows and turn on a fan.
    And also, either if you're using a heat gun, or an oven (best, because the heat is even) or a stove top (one guy actually used this method), don't overheat. Bubbles will form on the plastic and ruin your project.
