Other Valve announces Scan to make a Steam box
Discussion in 'Hardware' started by HeaverNothing, 7 Jan 2014.
  1. HeaverNothing
    HeaverNothing Professional Idiot
    7 Aug 2013
  2. GeorgeK
    18 Sep 2010
    Strangely they would appear to be notebook parts...
  3. Shirty
    18 Apr 1982
    More of a "Steamtop" I feel...
  4. mrbungle
    20 Sep 2004
    That's not gonna be cheap.
    Nope nope nope.
  5. David
    7 Apr 2009
    Is Steam OS for the Steambox going direct to metal?
  6. Bede
    Bede Minimodder
    30 Sep 2007
    There were only a couple of <$600 Steamboxes, Scan was not one of them. I'd assumed they'd all be going for small, low-TDP, mid-spec boxes but apparently they see a market for up-cannoned Steamboxes. Not entirely sure I agree with that assessment. A good proportion of them were just mid-tower cases, which I think missed the point entirely. Gigabyte's offering looks pretty good, a black GameCube imo.
  7. mrMonkeyChunks
    mrMonkeyChunks EVGA Cheesecake
    4 Mar 2012
    I believe that this is the image that is being touted around the internet as scans steam box.
    Basically a laptop without a screen isn't it? Not much flexibility for upgrading either.
  8. Shirty
    18 Apr 1982
    Not having found any evidence to the contrary, I have to assume that it will be, or at least with extremely low overheads from a very lightweight API.
    Otherwise it'll be a flop imho, it just won't offer any tangible benefit over other options.
  9. David
    7 Apr 2009
    I know they're going for an under the telly box, so they'll be targetting 1080p but, unless they are going direct, those are poor specs for a next gen gaming box.
  10. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Source http://store.steampowered.com/steamos/
    So Steam OS looks to be a Client interface running on a Debian system core. Think of big picture mode.
    Although it forces you to use 500gb HDD (will not install on less) install requirements : http://store.steampowered.com/steamos/buildyourown
  11. GeorgeK
    18 Sep 2010
    Sorry - what does direct to metal mean?
  12. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    I think like any of these Steam boxes this one won't be cheap. Any box with the OS already installed and configured will be expensive. Much better to build your own :)
  13. David
    7 Apr 2009
    The idea is that without the overheads of an API like Direct X, coding directly to the GPU will return much greater performance.
    You can only do that with known quantities though - the millions of different possible combinations of GPUs, CPUs, mobos and RAM makes it all but impossible to achieve.
    If you have a fixed spec like an XBox or Playstation, you can get much more performance out of relatively low power hardware.
  14. rici1241
    rici1241 Minimodder
    4 Jan 2011
  15. HeaverNothing
    7 Aug 2013
    Any one else think it's just too much for laptop specs? At 700 pounds its should have a SSD at least, the laptops do at this price, even if it does have a sexy aluminum body.
  16. GeorgeK
    18 Sep 2010
    Could the lack of ssd be down to steamOS needing 500gb minimum?
  17. HeaverNothing
    7 Aug 2013
    I think Scan aren't going at gamers, it seems to be more aimed as a HTPC with its small size and "Integrated Creative Sound Blaster Cinema"
  18. HeaverNothing
    7 Aug 2013
    They could have had a Hybrid drive which would of been much better.
  19. fuus
    fuus Rocking All Year Christmas
    4 Dec 2010
    The spec of this saddens me greatly, what with the beta boxes showing such promise...
    The fact that these boxes are going to be synonymous with 'The PC Console' should pushed Valve to have set the baseline at a desktop i3 and GTX 760 or equivalent...
