Valve software Demo PC by PilouX [SHIPPED]
Discussion in 'Project Logs' started by piloux, 8 Jun 2004.
  1. Caged
    Caged What's a Dremel?
    5 Dec 2001
    Dude this is yet another quality case, looking to be even better than Blackmesa. Keep up the good work, I'm sure you won't disappoint.
  2. Omnipotence
    Omnipotence What's a Dremel?
    5 Nov 2003
    Yep, you've hit the nail on the head. I just couldn't be bothered :p
    But yes, I think something along those lines would look quite cool.
  3. piloux
    piloux What's a Dremel?
    12 Nov 2003
    hello :)
    thx for comments ;)
    don't worry about the perspex, it will be time dmage later
    I have finally decided how to integrate the bix² on top of case
    here is it @ its final position ,after the first paint coat
    the fans will extract the air from the case , I think this is much better about the internal temperature
    mod on
    :dremel:
  4. piloux
    12 Nov 2003
    nice idea guys :) I ll see what I ll be able to do with it ;)
  5. apHytHiaTe
    apHytHiaTe What's a Dremel?
    9 Jul 2004
    Piloux, I just decided that whats so cool about this project is that you've gone a little less crazy with the rust. The last one was cool, but too rusty. It looked like there might be rats living inside of it (maybe that was ur intention?) But the more controlled use of rust that you have used on this one makes it way cooler than the other. Can't wait to see how the hard drive mod that Vazzini42 and Omnipotence were discussing turns out. :rock: :rock:
  6. n3vrmind
    n3vrmind What's a Dremel?
    2 Feb 2004
    maybe you and your case should get a walk on part in HL3, you can appear in a white coat and be a mad scientist :idea:
    what about it Gabe? this guys obviously a big fan of the game and it'd be a good thankyou for the new case
  7. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
  8. Speak Easy
    Speak Easy What's a Dremel?
    2 Mar 2004
    I agree, plus the limited rust could show an ongoing decay process or something. :idea:
    Anyway, great update, I can't wait for the next one! :clap:
  9. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    mmmmm i would have to agree with that, but ayways case is very nice, i do like how you still make it look all so easy, ( i know it;s not buts still) love the MOD, carry on with your good work
  10. piloux
    12 Nov 2003
    :D no that was not my intention... I prefer to give rats to my cat :naughty:
    this is some pics about the right pannel: (this is just the beginning of it...)
    and for those who asked me what paint I used :
    I used 3 dark grey bomb , need one more...
    :dremel:
  11. Bilbo Fraggins
    1 Jul 2004
  12. Raymus
    Raymus What's a Dremel?
    29 Jun 2004
    Since the window on this side is orange, are you going to use a orange tinted plexi for the other window instead of clear?
  13. piloux
    12 Nov 2003
    thx :)
    no , I prefer the clear one for the other side
  14. Bilbo Fraggins
    1 Jul 2004
    Where can you buy uv reactive plexy...
    Or where can you buy plexy? lol
    any links to sites for stuff??
    advise for my mod.. any help plese yours is soo good :)
    ITs soooo good i cant stand to look at my mod anymore :hehe:
  15. D B
    D B What's a Dremel?
    11 Apr 2004
    Here is a spot to purchase different kinds of acrylic , including fluorescent , they say that they "offer only cell cast acrylic sheet , the highest quality available .... will not melt when cutting on table or band saw ..." ...Delvie's Plastics Inc.
    DB
  16. apHytHiaTe
    9 Jul 2004
    Those aren't UV reactive tho, are they? :waah:
  17. Novakog
    Novakog What's a Dremel?
    17 Mar 2004
    Wow, I really like that neon plexi on the right side, and the Valve logo. The only thing that bugs me is that the "H" in the text that says "Half-Life 2" just looks like an I, did you take the pic before it was done? That's very minor, but any imperfection to this beauty catches the eye.Anyway, very sweet, works very well with the rest of the case.
  18. D B
    11 Apr 2004
    ApHytHiaTe wrote ... "Those are UV reactive tho, are they? :waah: "
    From there title , description and appearance , I would say they are UV reactive , they have others if your looking for some that are not UV
    Piloux ... Can't wait for the next update ... as I have said before , Bit-Tech has ...
    The Most Amazing & Accomplished & Professional Moders On The Planet ... bar none
    This is THE definition of "theme" case , just Awesome !!!
    DB
  19. NEOBOB22
    NEOBOB22 What's a Dremel?
    14 Jul 2004
    :rock:
    hello piloux! for your BIX², why dont return the Heatkiller "grill"...
    it will show 2 triangle in which you can paint that :
    :idea: :idea:
  20. theagent
    theagent What's a Dremel?
    4 Nov 2003
    lol pikoux :)
    <(-_^)>
