Valve software Demo PC by PilouX [SHIPPED]
Discussion in 'Project Logs' started by piloux, 8 Jun 2004.
  1. isisfreak
    isisfreak What's a Dremel?
    19 Jul 2003
    Very nice! :thumb: Your skills keep getting better. :rock:
  2. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Will you be using the front cover of the case or will it be as it is? Great work, love the effect it creates :D
  3. piloux
    piloux What's a Dremel?
    12 Nov 2003
    thanks guys :)
    I ll use the front bezel , I still have to give some modding to it :naughty:
  4. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    WOW!!!!!!!!
    What will you come up with next? :p
    MOD ON MASTER! :dremel:
    Cheers,
    Mike
  5. Piratetaco
    Piratetaco is always right
    15 Apr 2004
    piloux you could soooooo make a career doing this
  6. Jokke_r
    Jokke_r What's a Dremel?
    8 Jun 2004
    looks good, i would have liked a slightly darker color like in the HL2 pic but this looks good aswell (might be the pic though)
    this does differ alot from the other case i couldn't have guessed it would differ so drastically. although when you started modding this case it looked like it was heading in the same direction as the old one but it looks pretty different now... i hope you can squeeze in some cool looking valve or something on the front panel though... (the rusty optical drive looks pretty alone ATM)
    :thumb:
  7. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    Man, that looks awesome. Like Jokke said though, I would give that wall a slightly darker color, but also as he said it might just be the picture.
    Nice work :thumb:
  8. liquidhot
    liquidhot What's a Dremel?
    21 Jun 2004
    That is defnetly a sweet idea! Good job buddy!
    What did you use to get them to stay in place on the rod and on the side of the case?
  9. Markus
    Markus What's a Dremel?
    11 Jul 2004
    VERY NICE !!!
    The sidepanel looks great!
  10. malcolm
    malcolm What's a Dremel?
    8 Mar 2004
    Nice, I was hoping that the C17 case would have something similar for its front bezel.
  11. Nightingale_zero
    Nightingale_zero What's a Dremel?
    30 Dec 2003
    I like the dark greyish cooler myself because it looks more industrial to me. Also in the first HL game there was alot of dark grey in the machinery etc. Overall I find it very fitting what Piloux picked out color wise for this mod.
  12. ModKid
    ModKid What's a Dremel?
    5 Jul 2002
    Ok piloux i changed my mind, you create some sick **** :) and it's really turning out nicely, great job mate.
  13. Bones
    Bones What's a Dremel?
    14 Nov 2003
    Amazing work! This is a great case! :rock:
  14. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    On the original Blackmesa case, you started rustification as one of the first actions. however, on this one, you started off with that, but soon ceased; are you just trying to model the entire case first, waiting on paint, trying out a different rusting technique, or a combination of the above? Either way, nice wall, Piloux. :thumb: Very cool computer. :baby:
  15. piloux
    12 Nov 2003
    thanks;)
    sure , in fact when I started blackmesa case I have the idea to entire rust the case , then it was the first time I use thes paints and now I know how it turn out and I prefer to build everything I need to have an idea of the parts I want to rust or not...and after that make the paint job . there will be rust but not a lot like in the blackmesa case ; that will be the final touch of the case :)
  16. piloux
    12 Nov 2003
    the wall is screwed by the rear of the panel
  17. piloux
    12 Nov 2003
    I think this will be the front bezel next
    :naughty: :dremel:
  18. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Very, very very nice work on the side panel...
    Constructive criticism: The matched color on the city-17 building makes itlook kind of odd in my opinion, are you intending to paint this further and possibly add some detail to their bottom?
  19. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    I know this has nothing to do with the thread, but: what do you work as?
  20. piloux
    12 Nov 2003
    could you explain what you wnat to say with "kind of odd" odd = old?
    btw the grey I use is the base color , there will be a detail paint job in the end
