Electronics Vandal-proof startbutton?
Discussion in 'Modding' started by Ygd3n, 22 Dec 2013.
  1. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    Hey, first thread here. I am searching for vandal-proof buttons, ones that are retractive. The one I have now doesn't spring back, and that makes the computer shut off after 3 seconds.
    So I need a power-on button, that springs back!
    So I want an orange-LED, preferably in black, retractive spring switch, that can be shipped to Sweden, preferably within Europe.
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    A momentary or "MOM" switch is what you need. I'm not sure if FrozenCPU ship to Sweden but they have exactly what you want here.
    Edit:
  3. Big Elf
    23 Apr 2009
    WatercoolingUK have them in either 19mm or 16mm
  4. Nexxo
    23 Oct 2001
    If postage from the UK or US is prohibitively expensive, I'm sure one of us can order one in the UK and post it to you in Sweden.
  5. Ygd3n
    21 Jan 2012
  6. Nexxo
    23 Oct 2001
    It is the correct one. The LAS1GQ is a momentary switch, which is what you want. The LAS1GQ-Z would be a latching (push-on, push-off) switch, which you don't want.
    There are six contacts at the back. Two are for the LED, indicated with + and -. You can connect that straight to the power LED header on the motherboard; voltage is correct. The remaining four are for whatever you want to switch. One pair (1 and 2) are "Normal Closed" or NC; pushing the button breaks the contact. The other pair (3 and 4) are "Normal Open" or NO; pushing the button makes the contact. You want to connect your Computer power or reset wires to 3 and 4.
  7. Ygd3n
    21 Jan 2012
    Oh well, thank you so much for the clearence! :clap:
    Gonna order one soon :)
  8. Kyle P JMC
    Kyle P JMC What's a Dremel?
    25 Jun 2012
    Just an idea, but couldn't the one Ygd3n currently has be modified in some way? :dremel:
    There wouldn't be a need to order a new one then :)
  9. Nexxo
    23 Oct 2001
    Nope. He'd have to crack it open and remove the latching mechanism. It's finicky and delicate and he'll most likely just break it.
  10. Kyle P JMC
    25 Jun 2012
    OK, id probably do that bit too:
