Electronics Vandal Switch
Discussion in 'Modding' started by mopery, 18 Jun 2005.
  1. mopery
    mopery What's a Dremel?
    22 Feb 2004
    I have a Vandal Switch that I want to use as a momentary on/off switch for my computer. I hooked it up and I got the light to work. But as soon as I plugged in my power supply cord the computer would turn on. And it would shut down after 5 or so seconds. This kind of scared me so now I’m using the old switch. But if you have used one of these before can you help me to get it to work.
    How I hooked it up was with 2 wires. The Positive on the mobo connecter to the positive on the switch. And same with the negative. So that’s 2 wires in all.
    Any help would be great.
  2. Jabberwocky
    Jabberwocky What's a Dremel?
    23 Dec 2004
    I have some computers that do the same thing you described if they are unplugged or turned off via the rocker switch on the back of the psu. Did you try turning on the computer with the vandal switch after it was installed?
  3. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    sounds like the switch is closed. Since its closed it acts like you are holding the button down the whole time. open the switch then plug in your computer
  4. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    The switch is in "on" position. Press the switch again.
  5. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    But i thought all vandal switches were all momentary. So I would think his would be too.
  6. Rekarp
    7 Mar 2004
    not all of them are
  7. Ghlargh
    Ghlargh What's a Dremel?
    16 Nov 2003
    It could allso be a NC (normally closed) switch.
    If it is, you could either replace it, or use a 5V relay powered of 5VSB to make it NO (normally open)
  8. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You only had two wires to the switch? And the light was on and the computer ran without a push? You've connected it wrong, needs more than 2 wires.
    Do you have a part number? 3 or 4 contacts on the switch?
    Moving to Electronics
