Vantec Tornado fan screw size different from Chenbro gaming bomb case holes
Discussion in 'Hardware' started by Maniac618, 8 Sep 2004.
  1. Maniac618
    Maniac618 What's a Dremel?
    10 Apr 2004
    Hi guys,
    Nothing so far to do with my PC building mission has gone smoothly and this is no exception.
    I've bought a Vantec Tornado fan to put at the front of my Chenbro Gaming Bomb case.
    The case metal holes aren't quite big enough for the screws that came with the Vantec Fan. So screwing it in is madness and I haven't been able to yet. Also the plastic fan screw holes have no 'bite' to take the screws so how the hell are the screws meant to go into the fan itself? :wallbash:
    If I want air to be blown around the case and not out of the case by this fan. Does the moving part face the inside of the case or out at the grill? Help, as usual, oh and have I mentioned before that I'm a n00b?
    :waah:
  2. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    redrill the holes to make them bigger on your cash.. and all fans come without the tap in the fan.. you have to do it yourself.. its a pain yes (ive rounded off many screws doing this) but it has to be done
  3. Maniac618
    10 Apr 2004
    ok don't worry I've done it, crisis over.
