vapochill case Q
Discussion in 'Hardware' started by dead_man, 15 Nov 2004.
  1. dead_man
    dead_man Confucious say: WTF???
    4 May 2004
    just a question to the bit-tech community.
    with the vapochill cases. the ones that act like a fridge, is there a condensation problem with these (im talking bout the -10degree C case if ya kno what i mean)
    coz a mate wants 1 but a freind thinks that there will fry all the parts from condensation
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    there is a condensation problem; but that is solved with an evaporator. It evaporates the condensation on the CPU.
  3. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    If improperly installed, there will be a condensation issue. The evaporator does not handle CPU area condensation. In essence, what prevents against condensation is the useage of small stick on pads to heat areas around the cpu, as well as a good amount of neoprane, again self sticking, which stops moisture from getting in there, along with insulating the surroundings from the intense cold. Finally, most will fill any gap they see as well as the centre of the socket with dialectric grease, as well as coat the pins of the chip in a NON CONDUCTIVE thermal grease to stop pin rot. Finally, the seal of the evaproator head and the cpu along with the neoprane around it is airtight.
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    it looks like steve knows his stuff
  5. Tulatin
    16 Oct 2003
    *shrugs* steve's like a spongue for this lol. His next grand project... XP120 on the AXP... when i sell this hydrocool.
